replacing power steering fluid
Do I have to use the recommended Nissan dealer power steering fluid Or can I use any other power steering fluid?
Also has anyone ever used the turkey baster method of taking out all the power steering in the reservoir and just replacing the power steering fluid in the reservoir?
I would have no problem using non-Nissan power steering fluid. Just be sure and use exactly the type specified in the owner's manual, and I would use only fresh fluid.
Be very careful to not get even a tiny speck of dirt into the reservoir (clean the outside very carefully before opening the lid).
And I also would have no problem using the 'turkey baster' method of removing the old fluid. Might not get every drop of the old fluid, but then we don't get every drop of the old oil out during oil changes, tranny fluid changes, coolant changes, etc.
Power steering and power steering fluids have changed very little over recent decades, so you should have no trouble.
Thank you. I appreciate your feedback.
I'll let you know when I need a ride after my car breaks down on the side of the road lol
Finally got to this and it was easy. Made somewhat of a mess using the turkey baster but yeah lol. A few questions
1. The dealership said the fuild was getting bad but still looked some what new. ..is it bad to change this fuild too often? (If price wasn't an issue to buy fuild 24/7)
2. Also is it okay if I'm Somewhat over the max line? The reservoir has a weird shape too it so its hard to tell exactly
dont have to change it that often, i bet half the cars on the road today have original power steering fluid in them. little bit over the max line wont hurt as long as its just a bit
should be fine using ATF or any power steering fluid. as far as i know, its only Hondas and old luxury cars like Jaguars that need specific power steering fluid
2. I wouldn't worry about it being a little over the line, it won't have any negative effects on it, unless it's extremely overfilled!! Just remember hot fluid expands so it'll rise a little bit when it's get warm!
I know your suppose to bleed out the brakes but just curious if you can just replace the old fluid in the brake reservoir with new fluid?
Awesome thanks man. Also I wanted to try to do my brake fluid too...Do you know if this method would work with removing the brake fluid with a turkey baster?
Of course anytime! I wouldn't use the same method for brake fluid, brake fluid is hygroscopic meaning it actually collects water and over time you will actually have small amount of water in your brake fluid which produces a squishy pedal feel, and most importantly lowers the performance of the fluid, example; lowers the boiling point and freezing point of the fluid, also water in the brake fluid can cause parts to rust which is obviously bad!! Definitely recommend a complete flush of the fluid when it comes to brakes!!
Of course anytime! I wouldn't use the same method for brake fluid, brake fluid is Hydroscopic meaning it actually collects water and over time you will actually have small amount of water in your brake fluid which produces a squishy pedal feel, and most importantly lowers the performance of the fluid, example; lowers the boiling point and freezing point of the fluid, also water in the brake fluid can cause parts to rust which is obviously bad!! Definitely recommend a complete flush of the fluid when it comes to brakes!!
Good info man. When you mean by rusted parts does that include rust to the rotors and brakes etc..?
Hygroscopic my bad, damn autocorrect... Oh no as in inside of brake lines, master cylinders, calipers!! Just the internal parts of the brakes! It's usually recommended every 2 years or so for brake fluid for that reason! Hope that helps brother!
So why do they recommend doing changing your brake fuild so early? I can't tell what the color is suppose to be either lol
as said, you technically are supposed to crack the bleeders and all that when changing the brake fluid, but on my stuff i just use a turkey baster and drain/refill the reservoir. if youre around snow, the bleeders can rust up and seize. sometimes the bleeders then snap off with no effort. if youre in Texas i dont think thats a problem for you lol
So are you saying I shouldn't replace my brake fluid? I think my rear brakes are going out, but My front ones are still good.
that depends if you crack the bleeder when pushing in the caliper piston though, ive done hundreds of brake jobs and havent cracked the bleeder once
theres no harm in replacing your brake fluid if you want, i usually replace mine every 3-4 years
brake fluid should be a honey gold or clear, over time it gets to be a darker colour and there can be sludge in the reservoir
Haha yeah Texas never gets that cold. The fluid looks dark. So there's no harm in a Turkey baster drain and fill of the reservoir? As long as I clean it up and make sure nothing gets in it?
Where is the bleeder located at? Would hitting a curb at high speeds mess that up?
you can, but since your bleed screws are probably clean i would eventually do it properly with cracking the bleeders
bleed screw is on the caliper, no way you can damage it on a curb. only problem area with them is they can rust and brake off which is why i dont ever crack them open
look like this
look like this
![](http://www.driftopia.com/blog/wp-content/uploads/2007/09/240sxbleederscreworvalve1.jpg)
look like this
look like this
Thank you for the information too
![](https://maxima.org/forums/images/smilies/support.gif)
The turkey baster method wont work on brakes. The power steering system circulates the fluid which mixes the new fluid in the reservoir with the old fluid in the system. The brake system just pushes the fluid one direction towards the caliper so the old fluid would stay in the lines even with new fluid in the reservoir.
I'm aware that brake fluid is pushed through the brake system, (this isn't my first car). What I'm suggesting is that he change his old fluid in the reservoir and when his pads are changed he will have cleaner fluid in the system. If he drives like a mad man or does autocrossing of course the fluid would need to be changed totally. But for normal everyday driving the turkey baster will work just fine.
Personally, I just order 4 speed bleeders for $28.00 which makes it really easy to completely flush the system. That reminds me....I need to order them for my 2012 maxima.
even if it breaks off it wont leak, on my old rusty pickup i replaced a rear brake line and went to bleed it, just put a bit of pressure with a socket and the bleeder snapped right off
![laugh](https://maxima.org/forums/images/smilies/laugh.gif)
vingodine
45
05-21-2016 12:46 PM
scarletsosa
08-17-2015 09:09 PM
