Difference between O2 Sim & Non-Fouler
Old Nov 4, 2013 | 05:24 PM
Prophecy99's Avatar
Looking for some clarification. As I am getting a shop to gut my 2 precats.
Between Roch's and Tuner's two threads it answered and confirmed all my other questions on these topics (headers & precats). thanks to you both and they are must reads.
http://forums.maxima.org/5th-generat...00-2003-a.html
http://forums.maxima.org/5th-generat...while-car.html
thought about bumping them, but decided not too.
On to the question. What is the difference between installing an O2 Sim, and installing non-foulers?
From what I can tell a nonfouler is just a place to host an O2 Sensor regardless if it is an O2 sim or a regular O2 sensor?
At the end of the day, my newb question is what O2 sims and/or nonfoulers do I need prior to gutting both precats? (parts wise i know I should probably get gaskets and some bolts etc)
Also by putting all this work into the precats, is there any chance that I would actually need to do anything with them again after all of this? (thinking long term)
side note: if code p0051 = bank 2 sensor 1 upstream O2 (heater) Sensor is shot, would that possibly effect anything in regards to gutting the precats. In other words IIRC that sensor is on the front OEM exhaust manifold, and not the actual precat but since I am ordering parts I mind as well hit it all at once while I am in there.
Here's a pic depicting the Locations of the O2 Sensors for reference.
side note my intermittent code p0051 read bank 2 sensor 1, but according to that sticky pick my code should be Bank 1 sensor 1 ? what gives?
What I am thinking at 163k, if one bad the other is close. So if both front 2 O2 Sensors (upstream) are the ones that effect fuel economy (air fuel ratio), that they are worth replacing after 100k miles as a maintenance / peace of mind while I am in there.
PS. I thought about headers and I like my LTB Stage II more.
Thanks in advance!
Old Nov 20, 2013 | 03:30 PM
chopstic's Avatar
I'd also like to know the difference. I was able to install a spacer (non-fouler) on bank 1, but bank 2 is nearly impossible to get to, let alone have enough extra room for a spacer. it seems like an o2 simulator might be the easier solution....
Old Nov 20, 2013 | 04:25 PM
IceBerg's Avatar
Same situation here couldn't get a fouler on the other bank so I'm planning to use a sim for the second one
Old Nov 20, 2013 | 04:53 PM
HotshotVQ35's Avatar
when i had my 2002 max, i ran these o2 sims for years. car passed nys inpection everytime since there was no check engine light. the o2s were zip tied under the front valve cover. just gut the precats and wire this in, problem solved
http://www.3sx.com/store/comersus_vi...?idProduct=769
Old Nov 20, 2013 | 06:34 PM
IslandMax's Avatar
A non-fouler (spacer) is just a spacer for the o2 sensors, what it does is it moves the sensor out of the exhaust pipe a little. They are like 5 bucks from any auto parts store.
An o2 simulator is an electronic chip that simulated o2 sensor readings. It always reads good in order not to trip a code. Only thing is you can't just wire that in instead of the o2 sensor, you must keep the sensor plugged and only cut the signal output back to the ecu and wire in the o2 sim (sim also needs a power and ground). You do this to keep the heater circuit of the o2 sim, if you don't that will trip a code too.
Old Nov 20, 2013 | 11:43 PM
george__'s Avatar
get two non-fouler, drill it with a 1/2" bit... Then get another two.
Put them together
Done
Old Nov 21, 2013 | 04:33 AM
Prophecy99's Avatar
Thanks a lot HotShotVQ35 for the link! seems o2 sensors are harder & harder to find as time goes on.
Thanks, makes sense after reading your post, and hopefully helps others!
Old Nov 21, 2013 | 10:56 AM
chopstic's Avatar
Put them together
Done
are you suggesting to use 2 spacers per sensor?... that might work on bank 1, but bank 2 is so tight on clearance, i cant even get one spacer to fit in there.
Old Nov 21, 2013 | 11:13 AM
Flanker84's Avatar
Put them together
Done
I did this a couple of months ago. No regrets!
Replaced all the O2 sensors because the SES always pop up when I drove in Highway even before the installation of the "Y pipe". The Sensor #1 in both banks are installed as they must be, but the #2 sensors got spacers because the "Y pipe" was installed and I gutted the precat in Bank #2. No codes since then.
And yes, the space it's pretty tight and it's a PITA to install the no foulers, BUT it's possible in a 00 or 01 Maxima. I don't know if it can be done in the 02 and 03 Maximas.
Old Nov 21, 2013 | 01:27 PM
george__'s Avatar
I am doing the spacer thing on Cattman stuff
Old Nov 22, 2013 | 03:58 AM
honestly i would just buy that. i wasnt about to mess with those foulers. o2sim.com was taken down years ago. get this while you can!
Old Nov 22, 2013 | 04:59 PM
ACee's Avatar
Does anyone know if spacers work in an 03 ?
Old Nov 23, 2013 | 12:00 PM
03blackSE's Avatar
If by spacers you mean anti-foulers, yes they'll work on a 03.
I gutted my pre-cats about a year ago and have had no issues with the anti-foulers. Attached are some pics for you guys of the gutting procedure. I know some people recommend 90* anti-foulers for added effectiveness but depending on where the bend is, it's a tight space for our cars. I went with the straight one in the picture and have had no issues or codes after about 20,000+ miles.
After some digging of the rear (bank 1) pre-cat:
Rear (bank 1) pre-cat gutted:
Pre-cat material:
Anti-fouler installed for the secondary O2 sensor for the rear (bank 1). Note the tight space:
Front pre-cat removed from car. Don't mind the missing pre-cat material. I took the picture after picking at it. Most of it was intact but there was a lot of side to side movement. That is the secondary 02 sensor for the front (bank 2) side. Again, almost no room to screw on a 90* anti-fouler so I went with the straight one. Sorry no pic of the anti-fouler installed for the front but I used the same type as the rear bank:
Old Nov 23, 2013 | 12:14 PM
ACee's Avatar
Thank you.
Old Nov 24, 2013 | 12:17 PM
Rochester's Avatar
Hmm. You're welcome, Prophecy.
merovi bought my car almost 2 years ago, and AFAIK the SIM is still functioning as expected. Although he had to have the flex section of that old Cattman Y-Pipe repaired. Not too bad for 5 years and five NE Winters.
Old Nov 24, 2013 | 07:20 PM
Donkeypunch's Avatar
Dumb question, if you don't have any codes and all cats
are good, will gutting pre-cats throw a code?
Old Nov 25, 2013 | 05:09 AM
Rochester's Avatar
Yep. There will be no signal difference between the front and rear O2 Sensors, because you've removed the catalyst.
Old Mar 5, 2014 | 06:08 AM
DjHackStyle's Avatar
I used the same antifouler as 03blackSE and yes it fits on bank 1 without removing cat i just did it from under and i guess it is a tight fit but fits perfect with no issues.
Old Mar 5, 2014 | 06:24 AM
nsnrider's Avatar
I have used the o2simulators on my max before with no problems. Just a note to others, as of recently, o2 sim website is up and running, looks like they updated the simulator and the price went up too. Just FYI.
Old Mar 5, 2014 | 06:26 AM
clintb3astwood's Avatar
Had an o2 SIM for years as well. Never had a cat or secondary code either!
Old Mar 28, 2015 | 08:10 AM
Prophecy99's Avatar
whats the difference between DUAL and SINGLE, and do I need to order 2 of the O2 sims since there are 2 precats with thier own O2's ??
Old Mar 28, 2015 | 08:04 PM
nestorlugo's Avatar
Yo buddy ask yourself the same question?
Dual or single?
Dual is if you wanna sim two sensors or single if you wanna sim one....don't overcomplicate things....oversimplified is better...
Old Mar 28, 2015 | 08:25 PM
WTF?'s Avatar
Yes, you need a dual.
Old Mar 30, 2015 | 04:47 AM
Prophecy99's Avatar
i know but there are two sensors in seperate locations! i always over think crap.
do I need two duals? haha
Old Mar 30, 2015 | 05:54 AM
george__'s Avatar
BAha you sound like me when I was researching :P.
i) BUY DUAL OUTPUT O2 SIMULATOR (http://www.o2simulator.com/universal...put-p-184.html)
ii) O2 SIMULATOR HAS CONNECTORS FOR BOTH O2 SENSORS TO IT
iii) WIRE EVERYTHING iN ENGINE BAY
IV) HIDE O2 SIMULATOR & 2 O2 SENSORS IN ENGINE BAY
Done!
Old Mar 30, 2015 | 07:26 AM
Prophecy99's Avatar
thanks george for the relative post.
Old Mar 30, 2015 | 12:30 PM
CMax03's Avatar
Correction you keep the heater circuit wired to the 02 sensor!!!
Old Mar 31, 2015 | 04:46 AM
Prophecy99's Avatar
im so mechaincally handicapped, I may need a how to on how to wire/splice/heatsink these O2 sims in.
Old Mar 31, 2015 | 05:15 AM
george__'s Avatar
https://maxima.org/forums/5th-genera...tallation.html
Old Mar 31, 2015 | 07:38 AM
Prophecy99's Avatar
thanks george, awesome! so dated i guess didn't think to search.
Old Jun 13, 2015 | 06:53 PM
Super Shadow's Avatar
Not to hijack this thread, although that's exactly what I'm doing, with the o2 sims installed, will the ecu be able to still set other problem codes if something besides the cats go bad?
Old Jun 13, 2015 | 07:35 PM
rebelhell's Avatar
Yes, O2 Sims only report to the ECU as functioning O2 sensors. They don't inhibit the ECU from functioning otherwise. Actually if you don't have secondary O2's and no simulators, your SES light will be on all the time and you won't be able to tell if another code is thrown without scanning all the time.
I went awhile with no O2's and no Sims to replace them and I always worried that something would go wrong without me knowing about it because that damn light was always on.
Old Jun 14, 2015 | 06:06 AM
Thanks. Just curious. Only because it seems to be running a little weird lately and I have no codes pending at all. Guess I'll just keep my eye on my datastream for a while.
Old Jun 15, 2015 | 08:19 AM
CMax03's Avatar
Man all the info that was posted yrs ago is still available as well as the few O2 simulator sites that still exist and explain all this...The way this thread started was sorta weird...But I guess ownership of the 5th Gen's age continue to decrease and they're mostly youngsters that were still in grade school when these cars were introduced so I guess they're just learning the same way we did 15 yrs ago...
Old Jun 16, 2015 | 04:39 AM
Prophecy99's Avatar
yea i got my sim from 3sx.com , i agree with you, but the exact question between the two were hard to figure out through my research. it wasnt clear if they were the same exact thing with a different name.
to any defense, i never cared about exhaust, never wanted to be loud and ricey, but have learned alot past cpl years, thanks to the org.
i just gutted the pre-cats last night.
mkaresh
Mar 12, 2018 06:48 PM
doctorpullit
Dec 12, 2015 09:39 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Pied
Sep 26, 2015 03:29 PM
