Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
jclaw traction control bar set
Old Nov 16, 2013 | 09:27 AM
TurboA32's Avatar
Is anyone here using jclaw traction control bars and if so can you post pics of them installed
Old Nov 22, 2013 | 03:16 AM
TurboA32's Avatar
All the views and nobody has jclaw traction control bars
Old Dec 21, 2013 | 06:57 PM
grey99max's Avatar
LandShark has Cosworth
Hi - I just read this thread, and yes, I have the Jbars installed - they're part of the first production run he did, back in the day. Installation was easy enough, and I had to use a conduit bender to shape the driver's side Jbar to clear the automatic tranny. The passenger side was kinda close to the top of the oil filter so I used the short filter and no problems.
You remove the two chain-down eyes from the front frame (two or three bolts) and instead bolt in a steel plate drilled for the same frame holes and one hole for the bolt thru the Heim joint on one end of the bar. The other end has another Heim joint and a bolt goes thru that into an existing hole in the control arm The front end of each bar has a lot of adjustment since the Heim joint screws into the end of each Jbar, with a locking nut to keep anything from changing.
These work very well, eliminate wheel hop and improve steering stability.
I looked in my Photobucket account, but I didn't see any Jbars photos there.
lowpost99
Oct 26, 2025 06:53 PM
Starrider
Dec 18, 2015 04:43 AM
videomano
Sep 8, 2015 03:28 PM
