P1320 again!!! After 3 month-- replaced Nissan OEM coils and NGK plugs
I've had P1320 codes for over 2 years on my 2000 Maxima but car never stalled and drived fine for that time being. 3 month ago, I decide to fix the problem so I replace all 6 new nissan OEM coils 22448-2Y000 and 22448-2Y005 along with all new PFR5G-11 NGK platinum. The CEL code quick went away......for 3 month.....
Today the CEL code came back with only P1320 like before, Car still drives fine.
I could troubleshoot again by testing each coil to see which is triggering the CEL, but I want to know if there are any other sensors that would trigger
P1320??
Thanks,
P1320??
Thanks,
P1320??
Thanks,
P1320??
Thanks,
If not, then a harness wire may be damaged and you need to troubleshoot those. It was an issue on the 4th gens.
It sounds like one of the coils is out of spec, again. I would test each one. It's a stupid code that doesn't mean anything. But it will screw you if you live in a bastard area that requires emissions.
Also, would faulty crankshaft sensor also trigger P1320?
Thanks for the reply!
vingodine
45
May 21, 2016 12:46 PM
kirkhilles
Aug 8, 2015 10:53 AM
