Factory amp or not in 2012 maxima s?
I'm looking at upgrading to a new radio for my 2012 maxima S and the salesman is asking if the car has a factory amp. I don't know.. how do I tell? This is the upgrade I'm looking at buying -
Amazon.com: Oem Replacement In-dash Radio Dvd Gps Navigation Headunit for Nissan Maxima Teana 2009-2013 with Rear View Camera: GPS & Navigation
If your talking about the rear "subwoofers" then yes there's a little amp back there.
As far as that unit your looking at goes, I don't think it can be intergrated as a simple swap. But if it's done a lot of people here will be interested
Ya those 6x9s in back are considered the subwoofers, we know they aren't but that's what they call them. If u look in the trunk of an s model you'll see it's setup the same as the Bose system with a amp.. Also I'm pretty sure the s model system is made by clarion so it's half decent
Actually you can consider them subs, kind of lol. According to the FSM, the rear deck speakers split off to a small low signal converter or low pass filter which goes to the stock amp. All other 6 speakers will run off the headunit.
I have a 2013 Maxima S and swapped the speakers in them so I did some research to see how the system was wired.
Maxima s amp wire diagram
[QUOTE=Warriors55;8888047]Actually you can consider them subs, kind of lol. According to the FSM, the rear deck speakers split off to a small low signal converter or low pass filter which goes to the stock amp. All other 6 speakers will run off the headunit.
I have a 2013 Maxima S and swapped the speakers in them so I did some research to see how the system was wired.[/QUOTE
ef9
Aug 14, 2015 03:03 PM
Superbform
Aug 11, 2015 08:10 PM
MikesChevelle
Aug 6, 2015 11:36 AM
