Noob here need help!
Old Jan 20, 2014 | 03:22 AM
SplashMartinez's Avatar
So I just picked up my 99 maxima se 5mt 191k and when I close my hood not too hard the headlights dim and sometimes my drivers side goes out completely other times fogs don't work help?
Old Jan 20, 2014 | 08:21 AM
Slamrod's Avatar
Check all the connections for corrosion, also check the grounds.
Old Jan 20, 2014 | 11:01 AM
Old Jan 20, 2014 | 03:47 PM
Alaskus's Avatar
if you are doing that.. just take the time and clean up all the grounds/connections. At 191 they probably need it.
Old Jan 20, 2014 | 04:19 PM
litch's Avatar
it would be a great investment to get the grounding kit that is made/sold on here. Solve all your problems/decent upgrade/cheap.
Old Jan 21, 2014 | 09:50 AM
6cyl-97maxima's Avatar
Forget the grounding kit. IMHO, it is much better to clean up existing grounds and avoid having a huge mess of wires under the Hood as well as the confusion it may cause other mechanics when diagnosing future problems, since your wiring would no longer be stock.
Old Jan 21, 2014 | 01:41 PM
clive's Avatar
100% chingon
Right ON. No need for grounding kits. Similar sort of idea to "oxygen free loudspeaker cables"
Old Jan 21, 2014 | 02:01 PM
"Testing...testing", tap...tap...tap, are these cables wired correctly" .
LOL
Old Jan 21, 2014 | 07:14 PM
Just found out their hid so new answers?
Old Jan 21, 2014 | 07:47 PM
Amerikaner83's Avatar
Check ballasts...
Old Jan 21, 2014 | 08:19 PM
Dvohm meter?
Old Jan 21, 2014 | 08:56 PM
Check ballasts...
Agreed. or check for loose connection at bulb. Wiggle the wire while the headlight is on. In fact, wiggle all connections related to your HID kit while the headlight is on. You'll probably find the culprit.
Old Jan 21, 2014 | 09:08 PM
Old Jan 22, 2014 | 07:05 AM
Patm-a32's Avatar
Check ballast connections & or replace ballasts. My fogs also sometimes did not work check connection to the wire harness for the fogs
AaronL
Nov 15, 2020 11:52 AM
sake1bs
Sep 19, 2015 09:32 PM
Hawkeye61
Aug 12, 2015 06:45 PM
Habibshaib
Aug 6, 2015 01:19 PM
Max Noob
Dec 26, 2003 01:52 AM
