Headlight issue
Old Jan 19, 2014 | 08:27 AM
QbanCgar's Avatar
Headlight issue
hello, i'm new to this site & i'm having a slight issue w/ my wife's passenger side headlight. i noticed about a week ago that herb passenger's side bulb went out, so i finally got around to changing it yesterday. well i changed both bulbs w/ 2 brand new bulbs & still nada w/ the right bulb. should i next change to the fuses (in & out) to see if that will fix the issue?
Old Jan 19, 2014 | 09:00 AM
CMax03's Avatar
Check your bulb receptacle/connector maybe it's melted the connector body and not allowing the contacts to fully connect....Pep Boys sell Hi-Temp connectors and them seemed to cure my problems on both my 4th and 3rd gen headlights which run high wattage bulbs! Break out you VOM and start checking the connector's pins.
Old Jan 19, 2014 | 09:59 AM
max ride 41's Avatar
time for an upgrade!!!
Old Jan 19, 2014 | 11:20 AM
JoshG's Avatar
buy new headlights, nice and shine.
Old Jan 19, 2014 | 03:17 PM
DennisMik's Avatar
It could be a fuse. Each headlight has it's own fuse. The fuses are under the hood by the battery and are labeled H/LAMP RH and H/LAMP LH.
In addition to checking the bulb socket, it is a possibility for a bad switch on the steering column,
Old Jan 19, 2014 | 04:02 PM
QbanCgar's Avatar
thanks i will check that hopefully by weeks end.
Old Jan 19, 2014 | 04:07 PM
QbanCgar's Avatar
this was my next step, but it was cold as F*CK the day i changed her headlights, so i wanted to get it done as soon as i could. i'm hoping it warms up a little this week for me to check it during her my lunch. thanks in advance.
Old Jan 19, 2014 | 07:16 PM
asand1's Avatar
Check the grounds. A bad ground on that side would cause both high and low beams to be dead.
Old Jan 20, 2014 | 06:23 AM
QbanCgar's Avatar
high beams work fine, but it doesn't hurt to check it while i'm looking under there. many thanks!
Old Jan 20, 2014 | 04:41 PM
DennisMik's Avatar
Fuses and grounds will affect both the low and high beam.
If the high beam works, then the wire connection in the socket for the low beam has a problem or the headlight switch has a problem.
Old Jan 22, 2014 | 07:07 AM
Patm-a32's Avatar
Check fuses and or connector/ harness ect
Mar 12, 2020 12:06 AM
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
mpbclutch33
Sep 8, 2015 06:21 PM
MaxLife17
Sep 8, 2015 02:36 PM
