spark plugs
Old Jan 28, 2014 | 05:29 AM
Patm-a32's Avatar
spark plugs
hey guys I would like to change my spark plugs and its been a while since they've been changed and I keep putting it off, anybody know how difficult this can be? cause I know that some of them are difficult to get to but they need to be changed thanks
Old Jan 28, 2014 | 06:01 AM
Aflion's Avatar
Not that hard. Hardest part is getting the plugs out, but you use the boots for that. Use them to put new ones in, too. Definitely use NGK plugs. Lol.
Posted from Maxima.org App for Android
Old Jan 28, 2014 | 09:09 AM
98maxaholic's Avatar
Go to youtube, theres a few how to clips on changing plugs in the 4th gens!
Old Jan 28, 2014 | 01:30 PM
njmaxseltd's Avatar
Don't change the plugs, sell the car. Much easier...
Old Jan 28, 2014 | 01:41 PM
maxim14212's Avatar
Hello. The procedure of changing these spark plugs is really easy for the front, but quite hard to change in the back. I suggest the people to watch carsandtoys youtube channel videos on maxima repairs. Best of luck to you in changing the rear spark plugs.
Old Jan 28, 2014 | 01:55 PM
tosheto's Avatar
It is very easy if you have basic tools and mechanical knowledge.
Old Jan 28, 2014 | 03:03 PM
other than cyl 5 i think (rear bank driver side) its prety much the same for both banks!
there is just a one thing you gotta move outa the way. (Cyl 5)..and that too is pretty self explanatory and easy also!
Old Jan 28, 2014 | 03:06 PM
maxinout93's Avatar
very easy both front and rear plugs, about a 30 minute to 45 minute job. Just unscrew and remove each coil, I usually do 3 at a time, then the other 3. When installing I always use a rubber hose on the tip to prevent crossthreading.
Old Jan 28, 2014 | 04:34 PM
njmaxseltd's Avatar
Hello. The procedure of changing these spark plugs is really easy for the front, but quite hard to change in the back. .
Huh?
Same process for the rear as for the fronts. Two 8mm bolts hold a coil down, then a spark plug socket gets them out. You do have to remove two 12mm bolts to move some emissions stuff to get to one cylinder. No biggie...
Easy as can be.
magiconthetire
Oct 26, 2015 09:03 PM
Need help
23
Oct 2, 2015 08:56 AM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
