spark plugs
spark plugs
hey guys I would like to change my spark plugs and its been a while since they've been changed and I keep putting it off, anybody know how difficult this can be? cause I know that some of them are difficult to get to but they need to be changed thanks
Hello. The procedure of changing these spark plugs is really easy for the front, but quite hard to change in the back. I suggest the people to watch carsandtoys youtube channel videos on maxima repairs. Best of luck to you in changing the rear spark plugs.
there is just a one thing you gotta move outa the way. (Cyl 5)..and that too is pretty self explanatory and easy also!
very easy both front and rear plugs, about a 30 minute to 45 minute job. Just unscrew and remove each coil, I usually do 3 at a time, then the other 3. When installing I always use a rubber hose on the tip to prevent crossthreading.
Same process for the rear as for the fronts. Two 8mm bolts hold a coil down, then a spark plug socket gets them out. You do have to remove two 12mm bolts to move some emissions stuff to get to one cylinder. No biggie...
Easy as can be.
06-06-2017 02:01 PM
magiconthetire
10-26-2015 09:03 PM
Need help
23
10-02-2015 08:56 AM
