taking apart center console - help!
Old Jan 18, 2002 | 07:30 PM
maxirizzo's Avatar
alright, the buzzes and rattles from the center console around the radio/hvac on my 2k GLE are killing me. I know there is a TSB issued on fixing the various rattles, etc on the car, but first things first...how do i start to take the faceplates, etc off the radio and HVAC - i cant seem to find any screws, etc. Thanks again fellas.
Old Jan 18, 2002 | 07:49 PM
pjandres's Avatar
At your own risk, yank the thing off by getting a grip with your fingers thru the vents and pulling -- it will give. Just be carefull not to break the panel.
Old Jan 18, 2002 | 08:53 PM
ItalianMax2kSE's Avatar
DO NOT pull from the vents! You WILL break them. Get a flat head screw driver and pry the pieces up individually. Starting at the bottom with the shift piece. The top vents are very tricky, but w/ some force (be carefull-it is only plastic and that means it WILL snap)you can do it. I have about 3 times.
Old Jan 18, 2002 | 09:42 PM
2002 SE TX's Avatar
It's best to pry the bottom of the vent assembly up a little from the top of the readio before you try to pull the vents out. Once you've got it to pop up a little on the bottom of the vents, use your Kung Fu Grip on the bottom of the assembly and pull straight out. I just did it on my 2K2, and it was easier than my '97.
"The First Time is the Hardest"
Old Jan 18, 2002 | 09:48 PM
magnum's Avatar
take out the piece by the shifter first. everything sounds and feels like its gonna break, and everything comes out with a big "snap" that sounds like it is breaking, but have faith, it will not. its just what it does.
TKHanson
Nov 24, 2018 01:39 AM
gigabyte
Jan 6, 2017 06:05 PM
