Couldn't find this anywhere (Bose problem)
Old Feb 13, 2014 | 05:20 AM
SplashMartinez's Avatar
So recently I went to replace the front right speaker Bose* turns out the speaker isn't bad there just no power getting to that side help?
Old Feb 13, 2014 | 05:49 AM
njmaxseltd's Avatar
Check fuses.
Old Feb 13, 2014 | 05:54 AM
Check the fuses? 22 powers all for speakers so how could it affect that one speaker?
Old Feb 13, 2014 | 06:27 AM
Aflion's Avatar
That channel on your HU could have died, or there could be a short or breakage in the wire somewhere.
Posted from Maxima.org App for Android
Old Feb 13, 2014 | 09:04 AM
DennisMik's Avatar
If there is no power to the speaker, then the channel in the head unit is not the problem. Since all speakers get power from the same fuse, it is not a fuse.
If 12 volts is not on the red wire at the speaker (pin 5), then it is a wiring problem.
Check wire continuity from the audio amp relay to the speaker connector. The relay is located on the passenger side of the car, behind the kick panel that is in front of the door.
Old Feb 13, 2014 | 09:06 AM
Old Feb 13, 2014 | 01:22 PM
6cyl-97maxima's Avatar
Yeah I was going to tell him to whip out the multimeter and start tracing wires looking for bad grounds, or shorts on the positive wires. But you beat me to it Denis
I must say that you are very knowledgeable and always give correct info.
Old Feb 13, 2014 | 10:23 PM
DennisMik's Avatar
I appreciate the kind words. If they were only true...
Old Feb 13, 2014 | 10:26 PM
clive's Avatar
100% chingon
Probably the relay.
Old Feb 14, 2014 | 09:03 AM
DennisMik's Avatar
Have to disagree with you, clive. The relay sends power to 4 speakers. 3 of the speakers are getting the power. If the relay was bad, none of the speakers would have any power.
Old Feb 14, 2014 | 09:51 AM
slickblack94's Avatar
what if it is as simple as the replacement speaker's amp is also blown.
Old Feb 14, 2014 | 10:00 AM
DennisMik's Avatar
Since the op said he replaced the speaker, that would mean he replaced the amp also.
Old Feb 15, 2014 | 05:35 AM
maxinout93's Avatar
you may have to run speaker wire from your headunit to that speaker. I had to run wires to all 4 of my speakers after I kept blowing the audio fuse.
Old Feb 16, 2014 | 12:18 PM
JoshG's Avatar
just buy new aftermarket speakers, they will sound better. plus it shouldn't be that expensive.
Old Feb 16, 2014 | 05:19 PM
mista0406's Avatar
may be a bad wire connection at the HU... you could run a wire from the other front speaker (from behind the HU of course) and get it working like that, you just will not have the balance option (L/R) for the front speakers.
6spd4dsc
May 9, 2022 12:30 PM
boomerbrian
Nov 8, 2015 05:10 PM
homeyclaus
Sep 3, 2015 06:15 PM
gizzsdad
Aug 19, 2015 01:01 PM
kirkhilles
Aug 8, 2015 10:53 AM
