Maxima QX starting problem
Hello guys,
I am solving starting problem with my Maxima QX, 3.0 V6 AT. Most of the time it doesn't start. I recorded video:
Sometimes starts with problems:
Sometimes starts at first time:
I thought it is reliable on surrounding temperature, but isn't. I suppose, when the engine is heated up, it starts. I checked and cleaned batery terminals, grounding and CPS.
Does anybody has the same problem? Please help me with some advice.
Thank you.
John
Thank you.
John
One thing I noticed is that the engine is cranking faster in video # 2 than in video # 1. This could be a battery problem or it could be a starter problem.
In winter areas where the air temperature is around freezing, a bad ECTS (Engine coolant temperature Sensor) can cause this. Hard to start when the engine is cold and the car starts ok when warm is a symptom of the ECTS. If you can get someone to connect an OBD code reader to the car, check the engine temperature reading when the engine is cold. The temperature reading should be the same as the air temperature.
Lakersallday24
Nov 7, 2024 07:31 PM
kjlouis
Nov 24, 2018 06:09 AM
kirkhilles
Aug 8, 2015 10:53 AM
