Philips Daylight 4 Daytime Running Lights (DRL) with Auto-Dim module Instructions!
Old Feb 14, 2014 | 11:16 PM
nissandemigod's Avatar
Purchased some
Philips Daylight 4 Daytime Running Lights Philips Daylight 4 Daytime Running Lights
and just installed them the other day and they look awesome. Initially, was was going to install them in the brake duck area like everyone else here on the forum, but instead installed them in between the fog light area very easy, and I must say, looks amazing. They fit perfectly flush with the front of the car, so nothing sticks out, and look factory installed. I chose the Philips Daylight 4 over the 8 because I don't care for the 8 individual LED dots look, and because the Daylight 4 has 4 Luxeon Rebel Led's per light unit that split 6 watts, which is running each LED at around 1.5 watts, versus the Daylight 8 that has 8 LED's and splits 7 watts between them, running each LED around 0.875 watts. Needless to say the Daylight 4's are significantly brighter and better looking in my mind.
Things to know: Philips Daylight 4 comes with a regular on/off module, NO AUTODIM. Only the Philips daylight 8 comes with the Autodim module. """IT IS NOT HARD TO GET THE PHILIPS DAYLIGHT 8 REPLACEMENT MODULE FOR FREE, when the one that comes in the package is faulty for US cars and causes flickering, as the Philips Daylight was designed for UK cars! Just contact Philips and they will ask you for your mailing address""" Read through the Philips daylight 8 reviews from amazon and you will see how easy it is to get a Auto-dim module. Mine was sent UPS overnight!
Anyways on to the good stuff.
Installation was as simple as could be.
Once you have gotten your replacement Philips Daylight 8 module in the mail for FREE, proceed to installation.
10 STEP DAYTIME RUNNING LIGHT INSTALL GUIDE!
1. Place bracket where you plan to mount and drill holes in center area for wire connector to fit through, as shown in first pic. Confirm the ends of the DRL wire connector's can fit through the hole, if not make it bigger.
2. Screw on DRL mounting brackets, making sure to center the middle hole on brackets to hole you previously drilled.
3. Install DRL's, but DON'T snap into place just yet.
4. Connect control module's positive and negative wires to there respective battery leads.
5. Secure control module's ORANGE WIRE to left headlight wire in the hood fusebox, as shown in the picture, with a Posi-tap connector. You can also use a T-tap instead or solder it if you prefer. YOU DO NOT NEED TO CONNECT THE BLUE WIRE.
6. Connect DRL's to module and confirm they power on.
7. Turn headlight control **** to off, and confirm DRL's are at full brightness. Turn headlights on and confirm DRL's autodim. Turn headlights to Auto and make sure they are working correctly as well. Turn off the car and lock the doors to confirm DRL's auto shut off. Turn on the car and make sure they power up correctly.
8. Once everything is confirmed working, snap DRL's into brackets, making sure they are securely in place.
9. Screw down or zip tie the control module anywhere you want. Neatly zip tie all the excess wiring from the DRL's.
10. Enjoy!
Pay careful attention to the blue wire I tapped into, which is the left low beam headlight. If unsure, consult the fuse guide on the underside of the fuse cover!
HID's/Xenon's On with Philips Daylight 4 Auto-Dimmed. Headlights are on Auto.
Headlights turned off. Philips Daylight 4 at full brightness
Control shot with no lights on.
HID's/Xenon's turned on, with Philips Daylight 4 auto-dimmed
Headlights turned off. Philips Daylight 4 at full brightness!!!
I hope this guide helps anyone that wants DRL's installed, especially since the Philips Daylight 4's use Luxeon rebel LED's, some of the best, energy efficient and brightest 1 watt leds on the market.
Old Feb 15, 2014 | 01:27 AM
Shipwreck's Avatar
Great writeup! Thanks for this!
Old Mar 23, 2014 | 06:20 PM
Nopike's Avatar
Thanks for the instructions. I am thinking of adding these. Any chance you can add some photos of how they look during the day?
Old Mar 24, 2014 | 07:05 AM
I would but I have now upgraded them to the
Philips Daylight Guide Philips Daylight Guide
, which is around $220 on Amazon
But I can take a pic of those, as they are a little longer than the Daylight 4's.
After having both, I really like them both equally to be honest. I plan on putting the 4's in my headlight turn signal area though, and adding some halo's.
Old Mar 24, 2014 | 07:55 AM
Nopike's Avatar
Thanks. They both seem like good choices, depends how much one wants to spend. The daylight guides appear to have a wider beam so maybe aimimg is not as critical as compared to the 4 LED units? Post a pic of the new setup if you get a chance.
Old May 20, 2014 | 08:47 AM
slvrmax420's Avatar
I am getting ready to do this. Thanks for the write up. I was wondering if you could please take a picture of where you feed the orange wire into the fuse box. That is my only concern.
Old May 20, 2014 | 09:21 AM
Propa Teknique's Avatar
Oh wow, that looks good. I would certainly do this on my own but I really don't know anything about wiring. It actually makes me nervous thinking about doing this. I'll find someone to do this for me. Great write up and it definitely does great and bright!
Old May 22, 2014 | 01:40 PM
Kam007tv's Avatar
Do you happen to have a pic with then on during the day?
Old Jun 7, 2014 | 08:55 AM
maxipad2011's Avatar
So by tapping into the headlight wire does this make it to where they only come on at night or is it simply a power source for the DRLs whether the heads are on or not?
Old Jun 7, 2014 | 12:33 PM
Daaavid's Avatar
AFAIK, the Philips Daylight 8 comes with a separate module box with a blue wire that you tap into the headlights for. The module box will then automatically dim the LED, so you don't blind oncoming traffic whilst the Daylight 4 will shut off when your headlights come on. The OP found a loophole to get the module box that comes with the Daylight 8.
Old Jun 7, 2014 | 12:42 PM
Thank you just saw this post as I came in from installing them! It was actually the opposite from what I asked.....they are on in the daytime and turn off at night which is ideal since my halos stay on at night.
Old Jun 7, 2014 | 12:51 PM
Daaavid's Avatar
Pictures ASAP!
How do they compare to the eBay ones you had installed?
Old Jun 7, 2014 | 01:51 PM
Pictures ASAP! How do they compare to the eBay ones you had installed?
These are a bit smaller than the eBay ones in terms of width but fit perfectly and have great output!
Old Jun 7, 2014 | 05:02 PM
1996blackmax's Avatar
I'm liking how these look. Might have to give these a shot.
Old Jun 7, 2014 | 05:18 PM
Daaavid's Avatar
Thanks for the pictures. Any chance we can see this in direct sunlight instead of in the shade if you have the time? Still deciding where to place these if I bought them as I do not want to hack up the brake ducts yet since they are not a replaceable trim piece.
Old Jun 7, 2014 | 05:25 PM
I got these of the old ones before I started so you can see the damage done overall in these:
Old Jun 10, 2014 | 11:56 AM
slvrmax420's Avatar
Daaavid, your saying to connect the blue wire, from the module box, to the headlights? OP is saying not to connect the blue wire from the module box, but to connect the orange wire to the headlights.
Old Jun 10, 2014 | 10:20 PM
Daaavid's Avatar
Sorry, I was going off of the instructions on the Philips module itself that I have researched and read, and I was clarifying that the Philips Daylight 8 has a blue wire, while the Philips Daylight 4 does not which controls the automatic dimming of the LED lights when the headlights come on. I do not have the actual module in front of me, but it looks like the blue wire is actually from the car's fuse box and not the Philips module which is a separate entity.
Old Oct 12, 2014 | 03:59 PM
SuperCan's Avatar
Great write up! Nice to see some DRL's in a different location than the brake duct trim...
Old Oct 14, 2014 | 10:02 AM
official_style's Avatar
Would the newer philips ones fit in the brake ducts? Also does anyone have pics during the day closeup? I want to see what they look like mounted
Old Feb 15, 2015 | 06:55 PM
DomiChe's Avatar
I have a 2012 Maxima SV that I want to install the Philips DRL 4 in the brake duct. I wanted to know 2 things, 1) Is the lens on the units plastic or glass? 2) I want to keep the brightness of the light the same at night as during the day, is this possible? I saw that someone mentioned that the dimming feature is great as to not blind oncoming traffic, I believe that installing them in the brake duct, being that low on the car that it shouldn't blind oncoming traffic but those are my thoughts, I could be wrong. Thanks in advance. 1st time on here.
Old Feb 15, 2015 | 09:19 PM
The cover is plastic, but a very solid plastic, and super hard to get off. Everything onthe Philips DRL is industrial grade quality. I had to use a heat gun to get mine off, and somewhat ruined the mirror reflectors the LEDs bounce off. My advice, don't try to take it if.
Secondly, do not make the DRL's one brightness, they are very very bright and will blind everyone, even being in the brake duct. I tried it both ways, and people were so mad at me at night, including my friends. Trust me, the auto dim night feature is great, and you will still be definitely noticed at night, even being dimmed.
Old Feb 16, 2015 | 06:44 PM
DomiChe's Avatar
@nissandemigod Thank you for the advice. I will definitely put them on dimmer when I do. I was looking at the Philips DRL 9 and I don't really know which way to go, the DRL 9 or DRL 4.
Old Feb 16, 2015 | 08:53 PM
CHIBLACKMAX09's Avatar
I installed the drl4 in the brake ducts about a month ago and have them on full brightness all the time,no problems so far but i also live in chicago,they look great at night,look like i have led fog lights like the infiniti and don't even use my regular fogs no more...
Old Feb 25, 2015 | 06:11 PM
DomiChe's Avatar
Drl 4
@CHIBLACKMAX09 Hope that all is good. I ordered a set of Philips DRL4 for my Maxima. I am going to install them in the brake ducts. I was wondering if you had any pictures of the lights on the vehicle? If not, any recommendations? How easy was to install them? I am thinking of placing mine underneath the dividing bar within the brake ducts. Any info that you may be able to forward me would be greatly appreciated. Stay Warm & Be Good.
Old Feb 26, 2015 | 08:31 AM
I paid my guy 30 bucks to install them on top of the plastic bar, i dont know how to post pics but text me at 872 237 2556 and I'll send u some...
Old Feb 28, 2015 | 05:43 PM
DomiChe's Avatar
DRL 4 Installed
@CHIBLACKMAX09, Hope that all is good. Just wanted to update you on my project. I installed the DRL 4. I am happy with the way that they came out. I have full brightness, I see why they don't bother oncoming vehicles because in the brake duct, the angle is toward the corner of the car. I think I might want to get another set to put on the inside of the fog lights, lol. I won't, that would be too much. Thanks for the pics by the way. Stay warm.
Old Mar 1, 2015 | 10:41 AM
Cool,how much did they charge u to install? Maybe u can text me some pics...
tsi6001
Oct 3, 2022 10:23 PM
subwayhello
Aug 23, 2015 05:18 PM
spidgeon
Aug 18, 2015 05:46 AM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
