One thing that bugs me about the max...
The damn oil level rod. ON so many other cars its such a nice easy to read piece of metal. IT seems on our cars that as you pull the rod out of the engine it always gets oiled on its way out... ARgh... oh well
--- ps. i just added a 1/3qt.. its not just a random vent
Damn, I thought I was the only one with that problem. I usually get a better indication of the oil level by looking at the side w/o the markings and then figuring it out from there. I don't know how else to pull out the dipstick unless you mean to turn it 90 degrees when you're removing it. I've done that and it didn't help. This is interesting so if anyone can cliarify.
It's all in the technique
I agree it can be tough to check the level but just make sure your car has been sitting for awhile so that all the oil will have dripped downward towards the pan. It's less of a pain if you check it when the engine is cold.
Re: It's all in the technique
Thanks for the info though. Maybe I should get an oil pressure gauge instead of the idiot light? hehe
Re: Re: It's all in the technique
Originally posted by Toolrocks
That certainly makes sense and I've done it, but my manual specifically says to do it at proper operating temp.
Also another thing to add is when you check the oil do you wipe off the dipstick first and reinsert then check it? That also is the best way to get an accurate reading.
The tranny fluid, on the other hand, is checked with the engine running and up to normal operating temperature.
bigfrank
Oct 1, 2015 12:51 PM
