Water Pump whiny sound came and left?
so i got this 1996 maxima. today in the morning on my way to school the car started whinning out of nowhere. it smelled like something was burning. there was a little bit of white smoke coming out of the passenger side(left side of the engine bay) i think it was the water pump. car didnt overheat and normal. Drove it twice with the sound until.i decided to go.for.athird drive. Halfway to my ddestination the sound goes away. i pop the hood open no.smell or signs of something burning. Gone completely. Do.i go.on.and change the water pump? or do you guys.think there is something else wrong? coolant level was full and green. oil level full.
The power steering pump will make a whining sound when air gets into the system. Air in the power steering system would usually be caused by a leak. The white smoke could of been power steering fluid that leaked onto Your belt(s), which made of slip and the friction from the slipping caused the fluid to burn off producing white smoke
This is just a theroy, but I would check your whole power steering system for leaks, including the PS rack. You may have to start the car and crank the steering wheel all the way to the left or right, to get enough pressure to the system to help spot a small leak.
Again, just a theroy. But its very probable.
hope this helps
Nathan
hope this helps
Nathan
hope this helps
Nathan
hope this helps
Nathan
RWCreative
Sep 21, 2015 11:01 AM
BrandonCause
Sep 14, 2015 10:41 PM
Are you sure it's not his waterpump belt.
