Dyno of Stock Auto AE with K&N Drop-in Panel Filter
I went to ACS Racing in Hanover, MA this morning. They have a Dynojet, and every other Saturday is a Dyno Day where they charge $50/three runs. I wanted to get a baseline dyno before modding. The dyno runs are in 2nd gear, since WOT in 3rd makes it down-shift.
The numbers are SAE corrected. Uncorrected, they were 185 HP and 180 TQ! There was some nice cold air in there.
nice
To get a good run in 3rd though you need to start it off at a speed above where the shift mapping will kick it down to 2nd. Your results might have been even a little higher in 3rd gear
2nd gear lets you check out the low-end torque curve though which is also useful to see, esp on mods that seem to take away low-end power (JWT Popcharger ??)
Hey that is not a bad Dyno chart and numbers. Is that for a straight up K&N Panel filter drop in? Or also a OSCAI? Cause in a Sense that is like a Benchmark Dyno of what all 2K1 Autos are coming in at. I mean since you got a AE which is rated at 227 (dont know how) your tranny loss is about 21.6% if you rate it again the normal 222 engine (which is what I really think it is) your tranny loss is only 19.8%! I mean that is unbelievable. I thought all the AUTOs on the .org were doing about a 25% loss.
SteVTEC, Lets say he did start off in 3rd above the kick down point, then would your chart not start at like almost 3k rpms?
Also how much higher do you think the numbers might have been? You got any info/websites on how these DynoJets work and what SAE corrected means and all this good stuff? I have never dynoed my car. Done by my bike, but that is simple.
Dixit
Dixit
Dixit
Dixit
Yeah, the numbers are better than I expected, after hearing what other autos produce.
They tried running in 3rd, but I told them I wanted to start at 2000 rpm. Even at 3000 rpm, I think it'll downshift 3-2.
Originally posted by SteVTEC
OSCAI + K&N disqualifies you as stock
Dixit
Steve, any info on how these dynos work and which ones are better and what all this SAE corrected jargon means? You know of any website? I tried searching the net, did not find much.
Dixit
Dixit
Barometric Pressure 29.235" Hg
Temperature 77 deg F
0% Relative Humidity
0 ft altitude (sea level)
It makes the dyno data useful in comparing to others who run in different conditions.
Aight, maybe Kev can comment on this post. Why did you dyno with a Ypipe, RTcat, UDP, Stillen Muffler and only come up with a 181.5? That makes you only like 3hp better than RU4REAL's OSCAI 2001 AE AUTO. Something is wrong with your dyno chart.
Only reason I am asking is because next week I will have all the same things as you did on that dyno chart of yours last year, but I will be dissappointed if I get the numbers you did.
I want to expect about a 195whp with those mods compared to the dyno RU4REAL got.
Dixit
Dixit
He does have the AE too, which does also have the extra 5 HP although i guess there's been some debates in the past on whether the AE really does have 5 extra HP or not. hehe.
Anyways, as for dyno's, there are a lot of different dyno brands, but from what I've read and researched, Dynojet dyno's are generally considered to be the most accurate. Each dyno type calculates power in different ways also, and that gets you different results. And the dyno must be calibrated also.
Dixit
Dixit
Originally posted by Telus.net
Damn, sweet ride Irvine!
Yeah, awesome dyno too!
oh btw..my dyno was 204fwhp and 201lbs-ft tq w/ 84F intake temp and no fan...shiet..i want to dyno my car again with much colder air to see how much more i can make..
Originally posted by irvine78
thanks!
thanks!
204 is damn good if you ask me! The body kit looks like 300hp!
Okay,
I have an auto. I want more low end torque to improve fuel economy. Will the CAI help me gain more low end torque?
Okay,
Under hood intakes tend to give you the best mid-range respone with a balance of high-end and low-end power. CAI type intakes tend to give you the best high-end power, but at the expense of low-end power.
Dixit
Dixit
You're going to be disappointed because the highest auto dyno I've seen is 190.1 (nc00max and here's his thread: http://forums.maxima.org/showthread.php?threadid=57838. He dynoed 182 before his tranny fix: http://forums.maxima.org/showthread.php?threadid=55330 ). The average stock dyno is from 160-170 hp. There's no possible way you can get 195.
Let's say I put down 166.5 stock, so y pipe, CAI, UDP, cat, and muffler gave me 15 whp... which is about right.
Originally posted by Y2KevSE
Either his car is a factory freak or the dyno in 2nd gear threw the whole dyno way off.
I really hope when I get the CAI also, I can push at least 190whp. Then I will be happy. Then I wanna get boost like Kevy Kev.
Dixit
MAAAAAAAAAAAAAAAAAAAAAN, I was hoping on pushing about 195whp on my maxima. But like you said nc00max pushed 190.1 with nothing but a freagin OSCAI. I am kinda disappointed that a Ypipe, UDP, Testpipe, Muffler only give 15whp, but I guess I cant ask for too much.
Dixit
Dixit
Dixit
Dixit
You might not want to get a CAI (like what Hoon said), unless you want to leave a gigantic hole in your car.
Originally posted by ru4real
The next time I dyno, I'll do it in 2nd gear for direct comparison to my first dyno, and I'll also try 3rd gear at 3000rpm or above so it doesn't downshift. I want to see if 3rd gear changes the results significantly.
Good numbers Jeff. Finally I see someone post about the dyno place in Hanover, MA. Is the next dyno with Stevie's new intake?
Drop me an email next time and we can meet up. I want to check out your dynoing and hopefully a few other members.
Booooooooooooooooost.
Dixit
Re: WOW, drop-in K&N adds 6 hp.
Originally posted by Stealth Max
Good numbers Jeff. Finally I see someone post about the dyno place in Hanover, MA. Is the next dyno with Stevie's new intake? Drop me an email next time and we can meet up. I want to check out your dynoing and hopefully a few other members.
My next dyno will be with the FrankenCAR Stage 2 Intake. Do you want to go?
Originally posted by jkratzer
Is the OSCAI doing anything here or is the K&N alone the reason for extra the 6 hp?
I believe the K&N panel filter was dyno'd by Import Tuner magazine to gain 4 hp on the 5th gen Maxima.
Re: Re: WOW, drop-in K&N adds 6 hp.
Yes, the experience at ACS Racing could've been better. They made me wait about two hours before I could get on the dyno, because there was a Mustang GT on there and they couldn't figure out why the new supercharger was acting weird. Then they got into a long discussion about a small-block V8 intake manifold that had a hole in it. If you go there to dyno, see if you can make an appointment. Didn't someone post that if we get 10 ppl together, we can reserve the dyno for a day?
Re: Re: Re: WOW, drop-in K&N adds 6 hp.
Well the dyno place did notify me that the Saturday special is on a first come first serve basis. I was the one posted that if we can get ten cars to dyno then we can reserve a day for ourselves. Everybody wanted to go on their own time or for other reasons so we never did anything official like reserving a day like other car clubs. Yes I would like to go check it out next time you go dyno your car and maybe steve's 2k2 again.
Dixit
Dixit
Originally posted by nc00max
Looks like I'm a little late to this thread, but I'd thought I'd comment anyways. My dyno was right after I finally got the damned dealer to replace my tranny after they jacked it up. The 190.1 was with OSCAI, Y-pipe, and UDP, not just OSCAI. I'm pretty curious to see what I get now that I've replaced the OSCAI with the Cattman CAI, and added the RT Cat. The shop where I'm getting my NOS kit installed Friday has a dyno, so maybe I'll do some before and after stuff and see where I'm at.
Dixit
thanks!
thanks!
However, when both these runs were corrected to SAE conditions, they both came in right at 205 whp.
Originally posted by madmax2k
On my car I made an ACTUAL 204 whp with an 89 F intake temp. With a 72 F intake temp and much less humidity, the ACTUAL output jumped to 211 whp.
Dixit
aminus21
Sep 12, 2015 04:53 PM
