tint on tail lights
tint on tail lights
Okay so I'd imagine this may be a stupid question but I'm very interested in knowing what process was used to tint the tail lights on all these max's that I see? More specifically the pictures that have the turn signal cut out I think it looks awesome but have only seen pre cut tint kits on ebay with no cut out for turn signal. I'd really appreciate any help, I'm hoping it's a kit I can buy and do myself and not something that I need to pay a shop to do as I just sunk a crap load on wheels and other mods but think this would add the finishing touch to the car.
Thanks guys
Thanks guys
Thank you brother! I think you could do it yourself though...honestly after baking/opening my headlights to paint the housings I wish I would've just done the same with my tails and tinted them from the inside. You could do it though!
On the armada forum, a guy used I think two coats of plastidip black, then a coat of smoked plastidip, then another coat of black and still the light is very transparent through it. On my previous ride I got a shop to use tint film and it lasted the whole time I had it before trading in for this ride...
I used http://www.vhtpaint.com/products/niteshades/
Taped it off and did 3 coats. Light still coming thru
here is the link: http://www.clubarmada.com/forums/showthread.php?t=22876
i guess he only used matte black plasti dip but as you can see, light shines through nicely.
with vht, after a few years, it slowly fades from the weather, and it starts to look blotchy and faded. my friend did it on his g35 and 3 years later, its so ugly looking with the fade and he can't peel it off like plasti dip or tint film...
Just know that with the VHT that the lights WILL be matte finish which depending on the look you're going for, will not look good. I had a 2003 Mustang and it looked fine matte but on my Maxi I would have never thought of leaving it matte....maybe because it's black and stands out more matte?
With the sanding/polishing you're right it does look much better! I'm talking more about those that just hit it with the VHT and leave it as is....and definitely a no on the Plasti Dip Smoke! With sanding and even adding a clearcoat this not only adds protection but adds extra costs to sand/polish into to bring out a great shine.
Don't use VHT Nightshades. It is really dark and hard to create different light levels. I used Rustoleum Lens Tint. They sell it at Autozone. It is $14 a can which is outrageous but allows you to create much more custom levels of tint. I'll post pictures here in a bit. Vinyl overlays look good and are much less permanent. If you live in a hot area, they can wrinkle and shrink depending on the quality.
I removed my taillights and taped off everything but the clear middle part with the turn signal and reverse light. I wanted the inside to be a little darker than the outside. Sprayed one coat and then removed all the tape. Then sprayed the whole lights with another 3 coats. Then went ahead and sprayed on 3 coats of clear gloss enamel. Wet sanded with 2000 grit to get rid of the orange peel effect and then buffed with rubbing compound. Turned out really good.
@dr_2010SV: do you care to share how you did yours and do you have any other pics also? Yours are my favorite I've seen on the site.
Not sure I have the gumption to do it myself (don't wanna f 'em up) but yours are really well done so I figured I'd ask
I did them. The trick is masking each single LED light location so they get no tinting. Then do your Nite-shades and clear coating. I also masked the turns/back-up so they only got one coat of tint. Now I need to work on the front lights.
Cheers.
Thanks, I'm not sure since I pitched the can quite a while ago. Just remember to get a clear coat made for plastic's and that it has UV protection. Check out some of the You-tube videos for Nite-shade application.
fastcarny
Oct 6, 2015 10:42 AM
-ReLLiK-
Sep 8, 2015 12:02 PM
Maxima30
Sep 7, 2015 06:13 PM
I like the look of those lights. They do look very clean and solid! I want to get that done to my Max ASAP!
