Eibach Springs - Rear Toe Issue
Old Mar 26, 2014 | 09:47 AM
faze2988's Avatar
So I recently installed my Eibach Springs and got an alignment. The tech who did my alignment said he could not get my rear toe in spec. He was able to get the front camber and toe and rear camber in spec. I thought it should be opposite that they could get the toe in spec but not the camber. Does this guy not know what he is doing or is he right? I don't want to purchase any other camber kits or bolts because I don't mind a little bit of camber but I can not have the toe out of spec because it will destroy my tires. Any advice would be appreciated.
Old Mar 26, 2014 | 10:16 AM
dr_2010SV's Avatar
Sometimes when trying to adjust the camber into spec it will throw the tow out due to the geometry in the rear.
I have that issue on my right rear. So I settled for an "in spec" toe and a slight "out of spec" negative camber.
Also running 27mm rear spacers which doesn't help.
Old Mar 26, 2014 | 10:19 AM
faze2988's Avatar
So I have to tell him do negative camber to get the toe in spec?
Old Mar 26, 2014 | 10:25 AM
dr_2010SV's Avatar
Yes, as long as the neg camber isn't excessive. Another option is to use the 350Z rear camber arms. I have a set of these installed and still can't get my RR to come into camber, left is fine
Old Mar 26, 2014 | 10:45 AM
faze2988's Avatar
Thats so weird
Old Mar 26, 2014 | 04:22 PM
dr_2010SV's Avatar
Yeah I know. I even watched him adjust the camber on the right side, almost as soon as he achieved acceptable camber...the toe would go out. He fought it back and forth.
And without some kind of existing damage it makes me wonder about the consistency of the sub structure tolerances.
Old Mar 26, 2014 | 06:26 PM
bigdane71's Avatar
When you put the new control arms in the rear did you also put the lager toe adjusters? http://spcalignment.com/component/sp...AFrom&to=USATo
Old Mar 26, 2014 | 07:23 PM
MaxDOuT's Avatar
How did u achieve 27mm on a spacer??
Old Mar 26, 2014 | 08:12 PM
Racerbox77's Avatar
Toe wears tires much quicker than camber. Here's my specs. I did it this way for handling and flushness.
Old Mar 26, 2014 | 08:21 PM
dr_2010SV's Avatar
Something like this.....
http://www.ichibausa.com/ProductDeta...e=WS-25511466H
thinking about going to 30mm
Old Mar 27, 2014 | 01:01 PM
esco115's Avatar
Get your toe in spec don't worry about camber to much, an out of tolerance toe will wear your tire faster then an out of tolerance camber.
Old Mar 27, 2014 | 03:34 PM
GNCMaxima's Avatar
I have the same issue but I just got my camber kit in the mail so let's see if this will fix issue. I had -2 in the rear!
Old Mar 27, 2014 | 04:43 PM
dr_2010SV's Avatar
You know that's actually a very good question as I used the Ichiba arms and they looked to use a similar cambolt size as stock.
I now need to figure out if the SPC bolts are different than the Ichiba's
Still bugs me that I obtained alignment on the left though....
Old Mar 27, 2014 | 09:46 PM
GNCMaxima's Avatar
Wait do you need "the spc bolt" to put on the Ichiba's camber kit I got?
Old Mar 30, 2014 | 06:45 PM
1996blackmax's Avatar
Did they elongate the opening for the toe bolt?
Old Mar 31, 2014 | 05:15 AM
dr_2010SV's Avatar
I installed the Ichiba arms myself and I didn't need to elongate the holes on either side.
Left side is within spec with the right side slightly out (neg camber).
I need to check out the larger SPC cam bolt kit. Doe anyone know if the SPC bolts will fit the Ichiba arms?
http://store.specprod.com/productdetail/M50/1/1/72055
Old May 2, 2014 | 08:45 AM
Racerbox77's Avatar
the Toe bolts don't go in the aftermarket arms. They go in a diff hole where the spring bucket bolts to the subframe.
Old May 3, 2014 | 09:21 AM
GNCMaxima's Avatar
Which one is the Toe bolt? (noob question)
Old May 3, 2014 | 11:08 AM
dr_2010SV's Avatar
Alright, so SPC's description (from the website) for the bolts is as follows.
Comments:
These cams (set of 2) replace the OE camber and toe adjustment cams and provide additional camber & toe changes. Adjustment slots will need to be elongated using 85130 rotary files or equivalent.
So without viewing the video (showing the lower link) it's easy to assume that they are referring the bolt use on either the lower link or the camber arm or both especially if the bolt diameters are the same.
Remember, at either location you are affect BOTH camber and toe adjustment. You just affect more of the toe at the lower link and more of the camber at the arm.
Old May 3, 2014 | 11:16 AM
dr_2010SV's Avatar
You will see from this video that they are applying it to the lower link and not the camber arm.
http://www.spcalignment.com/componen...AFrom&to=USATo
Old May 3, 2014 | 01:38 PM
Racerbox77's Avatar
It's the bolt that attaches the spring bucket arm to the subframe
Old May 3, 2014 | 06:27 PM
GNCMaxima's Avatar
Wow yeah the shop I went to had no idea. First off they broke the toe bolt because they didn't know you had to install the bolt on the frame like one the video... am I screwed?
Old May 3, 2014 | 08:11 PM
dr_2010SV's Avatar
This...the exact reason I try and do most of my own mod work.
Old May 10, 2014 | 03:02 PM
GNCMaxima's Avatar
I 2nd that!
FML
dank4us
34
Jun 10, 2024 03:45 AM
Huttig2009
Sep 25, 2015 03:31 PM
95Maxi
35
Sep 2, 2015 10:37 AM
official_style
Aug 29, 2015 10:10 AM
Economic_Rage
Aug 20, 2015 08:27 AM
