Question about 2000 i30 exhuast.
Old Mar 31, 2014 | 04:34 PM
Jayr's Avatar
What's up guys. I been doing a little research on my car. Because I have to codes I'm trying to get rid of. Codes are p0420 p0430. Found out both codes are for my pre cats bank 1 & 2. And another thing I found out my car is cali spec,I do not have a o2 sensor after my main cat.
Now my question is I found a guy that was parting out a 2001 maxima gle, California spec. Ended up buying both pre cats with o2 sensors.
If the cars are only one year apart and same spec. I shouldn't have a problem putting them on right?
Old Apr 1, 2014 | 10:10 AM
Jayr's Avatar
Never mine. It fitted right on! Hopefully no more check engine light. I am getting a p0171 but its pending. And its now giving me a check engine light. So hopefully it goes away.
Old Apr 1, 2014 | 11:38 AM
DennisMik's Avatar
I doubt it.
P0171 is "Fuel Injection System Function (Lean) Bank 1"
Bank 1 is the side by the firewall. Are you using your original O2 sensors or ones that were in the y-pipe when you bought it? Because you probably have a bad O2 sensor.
Old Apr 1, 2014 | 12:28 PM
Jayr's Avatar
Im using the ones that where on the ypipe that I bought. Yea I figure its probably a bad o2.
Ima just change it. Its bank 1 sensor 1 current ? Will a Exhaust leak cause the problem too?
Old Jul 6, 2014 | 11:44 AM
Jayr's Avatar
p0138 p0136
Ok, so yesterday I decided to gut my front pre cat bank 2, to be exact. To clear the 430 code. I did the spark plug fouler trick. And put the fouler on the bank 2 sensor 2 red wire. Drove about 60 miles. Now cel popped up throwing codes p0138 p0136. Did some research and both codes are for the same o2. Bank 1 sensor 2 white wire? So the question is was I supposed to put foulers on that sensor too? Or is the sensor failing on me. Thanks
Old Jul 6, 2014 | 12:25 PM
colt149's Avatar
You need to use non fouler to both secondary 02 sensor to get rid of the code
( 02 sensor with white wire and 02 sensor with red wire: California emission spec.
Old Jul 6, 2014 | 12:51 PM
Jayr's Avatar
Old Jul 6, 2014 | 07:36 PM
CMax03's Avatar
Or a Dual O2 simulator!
Mar 12, 2020 12:06 AM
RinconI30
Jun 11, 2016 08:25 PM
RinconI30
Nov 10, 2015 10:55 PM
ballerchris510
Sep 11, 2015 05:29 PM
