2009 maxima running terrible
Old Apr 6, 2014 | 11:33 AM
ntrotter1's Avatar
I have a 2009 maxima that has been running very good till yesterday. It started fine then when it was put in gear it died. Now when you crank it it will hardly run. And when you put it in gear it will die. I checked the codes and it gave me a multiple cylinder misfire and cylinder 3 misfire code. Any suggestions? I was thinking a coil but it is almost running to bad to be one coil. And I think it would be weird for more than one to go out at the same time.
Old Apr 8, 2014 | 01:14 PM
maxud's Avatar
I would pull the spark plug and inspect. Then swap coil or plug (not both) with adjacent cylinder. See if the problem moves to new cylinder or stays. This way you will know what the issue is, i.e. spark plug or coil.
Replace as necessary.
The PITA maybe that #3 is one of the back cylinders, so you will have to pull intake manifold.
Old Apr 8, 2014 | 02:50 PM
zoemayne's Avatar
how many miles etc?
Old Apr 8, 2014 | 06:35 PM
koreanthunda's Avatar
😧sounds like a bad iac valve short etc .
LilVito
Oct 25, 2019 08:12 AM
Finkle
Sep 27, 2015 09:53 PM
09maxshawn11
Aug 14, 2015 10:07 PM
acw
Aug 13, 2015 12:50 AM
laparka66
Aug 6, 2015 09:36 AM
