Several Exhaust Questions for 2002
I'm finishing up my engine swap (putting a 2006 VQ35DE in place of the bad 2002) and it's time to start getting the exhaust pieces.
I've ordered the OBX headers and y-pipe as that is the first piece I need. That brings up the first question. Since this is removing/replacing the pre-cats do I need to get O2 sims/spacers/antifoulers for the sensors at the pre-cats? Or is the O2 sim/spacer/antifouler required only for the one in the y-pipe? Which should I get, sim or spacer? Sim basically eliminates the signal from the O2 sensor, but then I have to hang the sensor somewhere to keep the O2 heated signal. Will the spacer work fine then?
Does anyone know the diameter of the OBX y-pipe going back to the cat? 2.25" or 2.5"?
Next I plan on getting the Magnaflow High-flow cat to replace the rusted out original cat as that is what I saw recommended in a lot of the threads I've read. Is there a fourth 02 sensor by the cat? I can't recall as the exhaust was torn apart a while ago.
Would you get the 2.25" or 2.5" Magnaflow? I looked at Warpspeed at their cats and isn't the one recommended for the 2002 a little short at only 12.5"? I thought flange to flange should be about 16".
I then plan to get the SR-S axle back muffler. From what I can see that includes what looks to be a resonator in the mid-pipe section, so I won't be getting the Magnaflow resonator.
Anything else I might have missed?
Thanks.
Thanks.
There is not a sensor for the main cat, so just leave that one as is.
I'd say go as big as possible, such as the fastcat 2.75" or a 3" test pipe, but if you're going with the RSR cat back I think it's 2.5". As for the length of the cat/test pipe, the ~12" is what you want, 16" would be too long.
I wouldn't have figured I could use the 06 engine if it wasn't for this forum. Hopefully it will all go smooth.
I haven't found anything for the fastcat. From what I understand it is a Cattman product, but not finding anything on specs or where to buy it from. I've been looking at the Warpspeed cats as they are Magnaflows. I guess the 16" long one is for the older Maxima. I see the one for the 02 now and it is 12".
95-03 Maximas are 12". Ask me how I know.
Everything on the FC online will bring you back here to this site. In any case, it's 2.75", and here's my link for my FS stuff, it's in there.
http://forums.maxima.org/5th-generat...d-fog-kit.html
Justin Kroll
Sep 2, 2015 11:06 AM
