Wheels stick out
Old May 1, 2014 | 04:26 PM
Patm-a32's Avatar
Wheels stick out
Hey guys i have 18in g35 infinity wheels and the front wheels only** not the back wheels poke out almost as if i have spacers but i dont... This is keeping me from lowering cause they stick out a lot and ive seen other 4th gens with the same wheels that dont do this... I dont have spacers but i have after market drilled and slotted rotors that possibly are thicker than stock can this be my issue ? Or something else any help is apriciated thanks guys
Old May 1, 2014 | 04:32 PM
NmexMAX's Avatar
dot dot dot ...
Any pics of this? Which wheels do you have and are they staggered and if so, do you have the wider ones up front?
Old May 1, 2014 | 04:38 PM
Patm-a32's Avatar
No not staggered, and it looks the same if i swap fronts to back and backs to front the front wheels stick out and the backs dont. I will post a pick when im home later on
Old May 1, 2014 | 05:00 PM
Maybe you need negative camber up front?
Old May 1, 2014 | 05:31 PM
Patm-a32's Avatar
front
back
Old May 1, 2014 | 07:30 PM
Pics no work.
Old May 1, 2014 | 07:32 PM
CustomLowz's Avatar
Originally Posted by Patm-a32
front
back
Old May 1, 2014 | 07:33 PM
Patm-a32's Avatar
Originally Posted by CustomLowz
Top is front bottom is rear... It looks like this with any wheel any where on the car all four wheels and tires are same size
Old May 1, 2014 | 08:06 PM
Nealoc187's Avatar
SLOW
you've got wheels that are an inappropriate width and offset combo for your car bud.
Calabar's Avatar
I know this is off topic but where did you but g35 wheels and how much
Old May 1, 2014 | 08:11 PM
Crusher103's Avatar
When you lower the car the wheels come in a bit. My experience with G/Z wheels is they rub upfront if you run anything larger than a 235, The rear fenders MUST be rolled otherwise that sharp fender will chew your tires up fast.
Old May 1, 2014 | 08:37 PM
Patm-a32's Avatar
You sure man? My buddy i bought these off had them on his 99 se as well as me and they fit snug in his wheel wells and he had the car lowered
Old May 1, 2014 | 08:40 PM
Patm-a32's Avatar
Off a buddy who was junking his max i got them for next to noothing because it was my buddy selling them and they were beat up real bad with curb rash but i got them refurbished and powdercoated as soon as i got them
Old May 1, 2014 | 08:47 PM
Nealoc187's Avatar
SLOW
sure seems that way to me. did he have a lot of negative front camber? you drop the car and the top of the front wheels are going to camber in a bit. they won't stay vertical.
Old May 1, 2014 | 08:51 PM
Agreed. Something isn't adding up here.
I have G35c rims on my Max and they fit great. I only rolled my fenders for peace of mind, didn't really have to though.
See post #34
http://forums.maxima.org/members-rid...w-boosted.html
Old May 1, 2014 | 08:53 PM
Patm-a32's Avatar
Nope he had these wheels on just a stock se just with a lowering kit
Old May 1, 2014 | 08:55 PM
Patm-a32's Avatar
I did buy after market rotors for the front and they are wider than the oe rotor can that mabey be the cause ?
Old May 1, 2014 | 09:44 PM
Reality sucks's Avatar
No, pull all wheels make sure there not staggered. I've never seen this happen and I've had all kind of wheels on my car. Hell, this is a good thing actually. Smaller tire, rear spacers and drop, your set...
Old May 1, 2014 | 11:14 PM
asand1's Avatar
My fronts stick out more than the rear. They are not staggered, all four are 17X8" with 235/45ZR17.
Old May 2, 2014 | 03:12 AM
Nismo_Pilot's Avatar
based on what I am reading and seeing it seems that way. Measure how far they sick out and then pull your rotors and measure the rotor hub depth and thickness. Ill bet your tire measurement and the difference in factory vs your rotor thickness are a close value. Although they seem to be sticking out quite a bit, you are positive the offset is the same for all 4?
Old May 2, 2014 | 03:28 AM
It can't be the rotor(s) guys...Think about it...
I have a feeling the wheels are really staggered. Have you confirmed the offsets? They're stamped on the inside of one of the legs.
Old May 2, 2014 | 03:41 AM
dwapenyi's Avatar
That would be my guess.
Old May 2, 2014 | 03:58 AM
Patm-a32's Avatar
I know they are all the same if i rotate the wheels they still do this
Old May 2, 2014 | 04:02 AM
Patm-a32's Avatar
I might just get rear spacers to even them out ... What mm spacers should i use if i do this
Old May 2, 2014 | 05:28 AM
Which G35 wheels are they?
If you want to run a spacer, break out a ruler and measure how much you'll need then convert. 1" = 25mm.
Old May 2, 2014 | 05:52 AM
Patm-a32's Avatar
Okay so im thinking possibly my rotors could be causing this ?? The outer part of the rotor the part the part the wheel touches on the oe maxima rotors is 280mm and the rotors i have the outer diameter is 295.5mm can this be my cause??
Old May 2, 2014 | 05:55 AM
Patm-a32's Avatar
These are the wheels i got
Old May 2, 2014 | 06:27 AM
dwapenyi's Avatar
No that's the width of the disc itself. See the pic below? The measurements you gave are A. The problem seems to be C, the thickness of the hub;
Old May 2, 2014 | 06:28 AM
Matt93SE's Avatar
STFU n00b!
No.
How thick is the center section of the rotor- the part where the wheel studs go through? factory rotor thickness is roughly 1/4" there. to cause this problem, those aftermarket rotors would have to be an inch thick there, and I guarantee you they are not.
Old May 2, 2014 | 06:35 AM
Patm-a32's Avatar
Have power stop drilled and slotted... Idk how to check the measurments
Old May 2, 2014 | 08:14 AM
Rotors will not do this, they sit flush with the hub, it they were too wide for car, they would hit brackets among other things...Need to do more homework on your wheels, seems like just a fitment issue. show full pics of the wheels front and back, with numbers...
Old May 2, 2014 | 08:21 AM
Amerikaner83's Avatar
PLEASE listen to the multiple requests you've gotten to LOOK and VERIFY and give PICS of said wheels. Wheel info / specs / tire size also.
Also something to consider...the rears in the 4th gen are about 10mm further "inward" than the fronts... so the disparity could be somewhat attributable to that fact.
Old May 2, 2014 | 09:20 AM
njmaxseltd's Avatar
This is incorrect, it's not "C" it's actually the width of the front face plate of the rotor, where the studs go through. That's what sits against the hub. Think about where a spacer sits. There's no way the rotor is re-positioning your wheels, unless the rotor has a built in spacer. If that were the case you'd notice it by the length (or lack there of) of the studs threads, and it would be a pretty big heavy face on that rotor.
C - Positions the braking surface area properly between the pads on the caliper.
You have the incorrect wheel offset, (or a spacer your not seeing) that's what's throwing them out, nothing else.
Old May 2, 2014 | 10:54 AM
CS_AR's Avatar
I've seen an offset number stamped/molded in the inside of my Infiniti/Maxima wheels (on a spoke) to show the wheel width and offset. For example I have some Infiniti wheels that are 18/7.5/35 (for 35 MM Offset)
Can you show the numbers from inside the wheel?
Old May 2, 2014 | 03:14 PM
asand1's Avatar
THIS. If you want an even look you need spacers in the rear.
If you lower it, the wheel should move inward clearing the fender.
Old May 3, 2014 | 07:17 AM
Patm-a32's Avatar
How much of a spacer should i use ? If u can tell based on the pic of the back wheel
Old May 3, 2014 | 02:29 PM
Stock difference is 10mm so 10mm in the rear will make it even with each other, assuming the offset is the same.
Old May 3, 2014 | 10:37 PM
So no pics and proof of the actual offsets?
Old May 4, 2014 | 06:41 AM
Nah man, that'd be too easy
Old May 4, 2014 | 07:46 PM
Patm-a32's Avatar
Havent had time to been over loaded at work this week, will get pics up asap probly tomorow
Probebly will just go with the 10mm spacers in the back and lower it then and see what happens
