Rear driver door removal
Old May 3, 2014 | 07:16 AM
egali045's Avatar
Does anyone have videos or instructions/pictures on how to remove the rear driver door and have it replace. Theres like 2 screws that need to be remove and a couple cables. Thats where i will get stuck. Any advice.
Old May 3, 2014 | 11:29 AM
DjHackStyle's Avatar
You have to remove the plastic B pillar cover (inside the car) the lower part, becareful as this tends to have clips that break. Once thats off you'll see the plastic connector for the rear door harness you disconnect it from there and push it through the hole until its outside.
Now you remove the 10mm that holds the door check and the door opens wider for you to remove the 2 big bolts top and
bottom, DO NOT remove the hinge from the car, the correct way is to remove the door from the hinge because removing the hinge will mess up the door alignment and you will be very upset trying to align a heavy door.
Old Jun 7, 2014 | 01:22 PM
egali045's Avatar
Got it ! Found out removing the B pillar wasn't necessary but i did it anyways. the harness pops out through the outside as well.
MikesChevelle
Audio/Video/Electronics
Sep 11, 2016 06:36 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
delerium75
Aug 19, 2015 11:08 AM
