Advice on Re painting side mirror
Old May 6, 2014 | 07:50 AM
PH98I30's Avatar
Hi Guys,
I had to replace my passenger side mirror. It is sort of the same color as the car, but I decided to paint it anyway because the paint is all buggered up. How many coats would you advise I put on of color and how many coats of clear coat? I tend to over do things.
Old May 6, 2014 | 08:10 AM
Amerikaner83's Avatar
Sand it well (OFF the car, btw you don't want overspray )
three light coats
three coats clear
buff the roughness, polish, and you're good to go
Old May 6, 2014 | 11:53 AM
PH98I30's Avatar
Thank you for your reply. The mirror is off the car and masked off. I sanded and cleaned it up with alcohol. I appreciate your answer.
Old May 6, 2014 | 12:16 PM
throw up some pics when you're done!
Old May 6, 2014 | 07:22 PM
96i30azn's Avatar
I've painted my mirrors a few times. Only the little cover is painted so I like to remove it. You pry the mirror off it and access 3 screws and the cover comes off easily. This way, there's no chance of overspray because it's off the car.
Old May 6, 2014 | 07:23 PM
Finkle's Avatar
Depending on temps, you might be able to get away with two heavier coats. No less than two. I tend to use a slightly heavier final clear. If you are afraid of getting runs, go with three light coats.
The Wizard
24
Oct 1, 2015 08:47 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
flu2000
Sep 8, 2015 02:23 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
