Oil dirt 02-03
Oil dirt 02-03
Today I was checking to see how much oil I had and when I pulled out the stick that tells how much oil there is, it seem to have very little dirt on the tip. What is that a sign of? what needs to be replaced?
If by dirt you mean to say "dark or dirty oil" and only have a little oil on the tip means you are most likely down about 2 litres of oil providing your car is sitting on level ground and the engine has been off for at the very least 20 minutes, as it does take time for the oil to return back to the oil pan. The Maxima dip stick are horrible for getting an accurate read, so it is important to understand that the car must be on level ground and the engine has been off for at least the 20 minutes I spoke of.
Yea every time I dip the stick in there and take it off, It has like very llittle crumbs. I just filled it up with a gallon of 10-40w oil (it said about 3 quarts) and it still sounds like if it needs more. When I hit the gas pedal it makes a rattling sound. I don't know if it's just my car or all but when its low on oil, it makes a rattle sound when I step on the gas until I let go and hit the gas pedal again. How much oil does it support?
It is important that you verify that it is only one part or another that needs servicing. So you should be sure to properly diagnose the issue. You don't want to go through the trouble of replacing one part just to have it fail again because a root problem wasn't taken care of. That being said, those guides are usually the root problem. Just make sure to inspect everything in the timing area. It is quite important after all. Lol
couple seconds on startup isnt a huge deal, but when you get timing chain noise constantly at idle or acceleration you have problems. some Nissans are bad for the timing chain guides going
I believe i read somewhere that a lil chatter on start up was dew to the tensioner still building up pressure to push against the guide...and changing the tensioner via access hole was the fix .
But while it helped some others were not so lucky :/
This was an oil change or did it require almost a gallon to top off and read full on the dip stick? Three + quarts low is pretty serious oil consumption and could have caused oil starvation and some excessive internal engine wear.
litch
123
Jan 4, 2024 07:01 PM
05RLS2
Apr 14, 2016 11:49 AM
