Water pump time on a 96
My 96 Maxima has a small water leak that looks like it is from the weap hole between the timing cover and the engine block. It looks like water pump time.
Should I stay with a Nissan pump ($100+) or will a rebuilder's pump be okay?
Does anyone have a write-up on water pump replacement?
sup bro ..i had that same problem in nov..its the water pump ...n thats a pain in tha *** job bro.... they gotta take half that side apart...motor mounts.... belts..pulleys ...n jack ur engine up ...
the part is cheap..the labor is a ***** though .....
its about a 2-3 hour...if they know wha they doin ...if ur in nyc .. queens... i can hook it up ... my mech did mine in 2hours flat ..
wha i didnt know was...that..if u have the extended warranty from nissan..its covered::smackin self ova head :::~ got my $ back ...~ so nissan will cover it ...
Re: Water pump time on a 96
B) This is a PITA to do by yourself. Unless you're a seasoned mechanic, go to a reputable shop WITH the part in hand.
homewrecker
Aug 24, 2015 08:56 PM
