new rear caliper
Old 08-17-2014, 02:02 PM
bennuss's Avatar
new rear caliper
I had a bad caliper in the rear on my 01 so I replaces it but when I started bleeding the brakes I noticed that it doesnt go back it stays locked. the other side doesnt . Do you think I got a bad one? the piston turns fine and seems to be smooth.
bennuss is offline
Old 08-17-2014, 06:11 PM
Sean_a33's Avatar
I'm confused on what you mean when you say it doesn't come back after you bleed it. How about some more detailed info on everything going on?
Sean_a33 is offline
Old 08-18-2014, 06:42 AM
bennuss's Avatar
I had a problem with a rear right side brake. I heard terrible grinding si I took it off and the pad was completely gone and the piston was all the way out and would not go back . Note that the other side the pad was only half worn.
So I changed the caliper and and the pads and rotors on both sides and the car drives and the wheel spins but I get terrible excessive heat on that side and a smell like burning when i drive. My mechanic said i should have changed the hose that maybe the fluid isnt flowing properly . Anyway to test? Any other ideas?
Is there a reason why the posts are showing newest first?
bennuss is offline
Old 08-18-2014, 09:00 AM
bennuss's Avatar
Just took it to two mechanics to look at it. One said I should change the hose the other one said if the hose was clogged then it woukd build up pressure and fluid woukd come out when the bleeder screw was opened even when the brakes arent pressed. I did notice that the side with the new caliper doesnt spin as freely as the other side. Has much more of a draf. Neither mechanic coukd see anything wrong after checking the caliper and parking brake.
Any ideas?
bennuss is offline
Old 08-18-2014, 09:04 AM
njmaxseltd's Avatar
Did you remove, clean and lube the guide pins before you put the brakes back together?
njmaxseltd is offline
Old 08-18-2014, 10:03 AM
bennuss's Avatar
The caliper and pins are new and seem to ride freely.
bennuss is offline
Old 08-18-2014, 03:22 PM
BigLou55's Avatar
I am with njmax on this, seems like you have a lubrication problem. new doesn't mean it was lubricated properly. Double check that you have adequate lubrication. Any brake job you perform you should always clean and lubricate.
BigLou55 is offline
Old 08-18-2014, 03:34 PM
bennuss's Avatar
I did and both mechanics said that the pins are lubricated and ride freely
bennuss is offline
Old 08-18-2014, 03:53 PM
BigLou55's Avatar
And you bled the brakes until you no longer saw any air bubbles correct?
BigLou55 is offline
Old 08-18-2014, 10:10 PM
bennuss's Avatar
As best as I could . I want to get hold of one of those reverse bleeders. The reviews on bobistheoilguy after a lot of skepticism seems to be that it works well.
On a side note it looks like something easy to build.
Should I take the mechanics advice and change the hose or is that just a grab at some cash.
bennuss is offline
Old 08-19-2014, 09:32 AM
bennuss's Avatar
can Someone help please any ideas?
I cant drive the brake is burning
bennuss is offline
Old 08-19-2014, 10:04 AM
Suspension Yoda
djfrestyl's Avatar
I still believe the slide pins are the culprit. I actually take them to a bench grinder to ENSURE they are fully clean.
Also, clear out the hole in the torque member where the pins slide into. Lot of gunk builds up in there. Replace if you need to.
The 'new' caliper you replaced could also be poorly reman'd.
djfrestyl is offline
Old 08-19-2014, 10:57 PM
bennuss's Avatar
Changed the caliper and it seems to ride better. Although when I spin the wheel off the ground it doesnt spin as easily as the other side. The other side the pads are in contact with the rotor but arent putting any pressure. When I spin The side with the new caliper to me looks like it is slowing down much more quickly. I took it to my mechanic and he said it looks fine to him. I am going to watch the wear on the pads after i drive a little
bennuss is offline
Old 08-20-2014, 05:57 AM
Suspension Yoda
djfrestyl's Avatar
I would also do a proper bedding process.
I remember when njmaxseltd bedded my brakes wayyy back in the day - the rotors came back blue and smoking!
Old 08-20-2014, 03:57 PM
BigLou55's Avatar
It just occurred to me that one of your parking brake cables could be seized up forcing your brakes in slightly. Remove the cable from the rear caliber and see if you notice a difference while you rotate it in the air.
BigLou55 is offline
Old 08-21-2014, 05:39 AM
bennuss's Avatar
This was the first thing I checked. Anyways the I swapped the caliper and it seems to be fine.
any opinions on the reverse bleeder
http://www.brakebleeder.com/products...brake-bleeder/
seems like something easy to make . they have one that connects to a compressor also but the parts look like off the shelf.
bennuss is offline
Old 08-21-2014, 07:39 AM
Prophecy99's Avatar
id say seized parking brake cables, i had a brand new caliper and line replaced by a shop and the caliper froze the very next freaking day.
Parking Brake Cables need to be cleaned out each end and lubricated
i have had this problem over a year to two year and it always points to the cables.
Prophecy99 is offline
Old 08-22-2014, 05:54 AM
bennuss's Avatar
its easy to test. Just disconnect the cable and use your brakes. Which I did and it wasnt the cable. It was the caliper
bennuss is offline
matts95max
05-20-2024 01:16 AM
BkGreen97
04-02-2016 05:47 AM
bbsitum
09-11-2015 04:55 PM
beerman1378
09-08-2015 02:19 PM
Quick Reply: new rear caliper
