Engine Pinging
Old Oct 20, 2014 | 05:04 AM
BlackMaximus04's Avatar
Engine Pinging
So I let my sister drive my car & when she filled it up, she filled it with 89 octane gas instead of 93 that I always use. After she did when I cut my car off the pinging from the engine was very loud & noticeable. So I drove my car til basically I was about 10 miles away from empty. I filled it back up with 93 & the some of the pinging went away but it's still there just not as loud.
Anybody else know away to get rid of the pinging fully?
Old Oct 20, 2014 | 05:40 AM
KGMtech's Avatar
If you are talking about the ping you get driving under load, say up a hill, then you could add a bottle of 104+ octane from your local auto supply, or drive a little softer until you can top up the tank with your favourite 93 octane.
If it is the heat pinging AFTER the engine shuts off, in your driveway, this noise is perfectly normal and no amount of octane will affect it whatsoever. I suspect that because your baby was abused by the wrong grade of fuel, your ears are much more sensitive to any change in normal characteristic. I swear that each time my wife or boys drive my cars, they introduce a new rattle, quirk to my ride!
Hope this helps?
Old Oct 20, 2014 | 08:54 AM
14GmMax's Avatar
Id try some Marvel mystery oil mixed in your next fill up apparently there are testimonials saying that its solved all kinds of engine problems/noises. Good luck!
Old Oct 20, 2014 | 09:08 AM
Nopike's Avatar
And if that does not work you can try Seafoam
Old Oct 20, 2014 | 11:08 AM
187max's Avatar
Fuel problem .. Bad gas or injector is clogged up
Old Oct 20, 2014 | 11:26 AM
187max's Avatar
If it continues at idle you have a bad wrist pin ..
Old Oct 20, 2014 | 11:37 AM
Tommy6905's Avatar
It's normal, u prob just never noticed it
Old Oct 20, 2014 | 12:27 PM
jeffislouie's Avatar
Usually, the pinging you hear after shutting off the car is nothing more than metal bits cooling down. If that's all you hear, I wouldn't worry.
If the car is pinging while running, then you may have a bigger issue.
Old Oct 20, 2014 | 12:30 PM
Hope this helps?
Thanks for the info!! It was definitely after I shut the engine off. I guess I never paid attention to it before when I brought it because I never heard it til after she put 89 octane in it.
Old Oct 20, 2014 | 12:31 PM
Thanks for the info everybody! I definitely just never noticed the sound
Old Oct 20, 2014 | 01:49 PM
187max's Avatar
I thought you was talking about the engine while It was runing .. That ping bang noise is normal , mine does the same
Old Oct 20, 2014 | 01:59 PM
koreanthunda's Avatar
Yes it's the engine oil drops hitting the bottom of the pan and the engine cooling down which is completely normal .
Old Oct 20, 2014 | 02:22 PM
187max's Avatar
I agree .. He made it sound like it was inside the engine .. Glad it was nothing , used engine cost a whole lot of money plus labor
James92SE
142
Jan 2, 2024 09:23 AM
fastcarny
Oct 6, 2015 10:42 AM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
seesole
Sep 14, 2015 12:38 PM
