WA 00-01 OEM 5th Gen FX-R Headlight Retrofit
A pair of OEM 5th gen headlights retrofitted with FX-R 2.5" BiX with Phillips 85122 bulbs. It has pretty rare late model Infiniti M45 projector shrouds that have green tint which gives cool effect. Headlight lenses were also restored. The OEM turn signal bulbs and sockets are not included in the sale. I have this on my car for at least for 1 week and it has been working flawlessly.
$270 + Shipping.
Headlights were tested for leak prior installation and it is water tight. but light/mist fogging still happens when it weather is really wet and humid due to moist air that can't escape the headlight quick enough.
Light fogging on the corner by radiator. It will go away in about 30 minutes or so
Can't really tell from the frontal view though...
Built thread.
https://maxima.org/forums/5th-genera...ml#post8989832
$270 + Shipping.
Built thread.
Sold.
New rubber back cap. Make sure the turn signal bulb socket is installed correctly. This turn signal area is prone to let the moisture in.
W/50W Mori Ballast.
w/50W Ebay ballast (top), 50W (bottom)
You can see that ballast quality makes a big different in the beam intensity. I suspect they it will be the same case with 35W Mori and 35W aftermarket.
W/50W Mori Ballast.
vingodine
45
May 21, 2016 12:46 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
Finkle
Sep 27, 2015 09:53 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
