help with lower control arm
Old Jun 21, 2015 | 03:10 PM
jerrod99_se-l's Avatar
Need some advice...wheels on ground...i can put my foot on the tire and push it towards the back of the car....when you look under the car and do it...you can see the control arm shifting toward the back of the car...im going to assume the arm is toast...im also going to assume under throttle the arm is shifting to the back causing my tire not to be centered and making it shake really bad...anybody had this problem in the past..ive done the 12 and 6 and 3 and 9 with wheel off the ground and there is no play at all...control arm bushings shot?...just replaced the tie rod ends last week...any comments are more than welcome
Old Jun 22, 2015 | 06:33 AM
CMax03's Avatar
Sounds like the strut rod bushing is damaged or dissolved usually from a bad oil leak on the right side of the engine or accessories...
Old Jun 22, 2015 | 12:34 PM
JEB Davis's Avatar
All I can say is the job isn't that bad... just did both LCA's on a 1996 (Moog's from RockAuto) and they fit perfectly & included all the bushings & ball joints pre-installed. You'll need a ball joint separator fork. You might want to do the stabilizer bar links at the same time if they're rusty.
I can't wait to get the car on the road to feel the difference in the ride.
Old Jun 22, 2015 | 08:19 PM
I have all the tools...the more i think about it...is it possible the bolts are loose? Thanks for the replies
Old Jun 22, 2015 | 08:28 PM
Where is the strut rod bushing...not very good with suspensions...motors not a problem
Old Jun 23, 2015 | 12:14 PM
njmaxseltd's Avatar
Control arm bushings are shot, replace the whole arm. Might be worth it to do both sides at this point, it will tighten up the front end nicely.
Old Jun 23, 2015 | 01:47 PM
Thanks for the help everybody lca's friday
Old Jun 26, 2015 | 05:10 PM
Pulled the lca today and the rear bushing just fell off! Bought one from pick a part to see if that was the problem...and BAM! steering is tighter....little vibration from drivers side lca (replace tomorrow) man what a difference...night and day...thanks everybody!
Old Jun 28, 2015 | 07:08 AM
Nugent20's Avatar
glad to hear, and thanks for reporting back... I'm about to embark on the same journey. Did you use/need air for the LCA? Only have hand tools here and hoping to tackle. Car is also surface rusted underneath pretty decent...
Old Jun 28, 2015 | 07:21 AM
Daniel VQ30life's Avatar
you'll be fine with a breaker bar, if it's rusted like that tho I'd recommend a healthy dose of pb blaster before attempting to break anything loose
Old Jun 28, 2015 | 01:05 PM
Nugent20's Avatar
thanks, that's what I was thinking/hoping. soaking it every day for a week in advance or so...
Old Jun 28, 2015 | 01:35 PM
I'm sure that's probably overkill, but hey better safe than sorry i suppose
in which case I'd say get a torch and a couple replacement bolts ready
Old Jun 28, 2015 | 03:57 PM
I used a breaker bar and 2 foot piece of pipe..took a little longer...but i got it done..ball joint nut was the hardest...couldnt really determine the size 19 or 18 mm...but i got it off with the 18...end links were a snap as well...did stabilizer bar bushings as well...thanks again everybody...she rides smooth again
Old Jun 28, 2015 | 04:33 PM
jholley's Avatar
You got it easy using an open end wrench to remove the ball joint nut. On my heavily rusted LCAs I replaced several years ago those ball joint nuts got rounded off using an open end wrench. I had to slide the outer shafts via the knuckle to get a socket and impact wrench on those nuts.
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
AcuraLegend
Sep 22, 2015 04:22 PM
Bonka
Sep 14, 2015 11:18 PM
