Mess-less Oil Filter Removal?
Perhaps I'm just too **** but the mess made when removing our oil filter drives me nuts.
I can't help but do a motor wash-down after every oil change.
I've tried several options to try to avoid the messy motor from aluminum foil to Glad Press And Seal to painters tape ... no joy.
Have any of you guys devised some sort of guard or found some technique to keep oil filter run-off off your motor?
You should remove and tip the filter as rapidly as possible. Tip it so that the hole is facing up of course.
Loosening the filter, then sitting there while it caps all over the place is the reason you have a mess.
There is no oil in that area except what's in the filter.
You can drain the filter into your drain pan after it is removed.
Me? Yolo, spin dat bish off as fast as possible.
BTW, your oil pan and oil filter are not connected unless the motor is running.
You can remove your oil filter and still have a good 4+ quarts of oil in your motor.
JoshG
51
Sep 21, 2015 10:41 PM
97_GXE
20
Sep 17, 2015 08:12 PM
sdotcarter
Sep 2, 2015 09:53 PM
