2006 Nissan Maxima 3.5 SE Transmission problems
Old Aug 5, 2015 | 01:52 PM
Lakersallday24's Avatar
just signed up trying to get more information. I've been reading post about transmission problems. I have a 6th gen Maxima that no matter cold or hot once you put it into Drive it bangs badly. When you accelerate it slips in first gear and when coming to a complete stop it feels as if something is dropping from underneath the car. The weird thing about this is the problem will go away for a couple days then come back. It wasn't doing it for about 4 months then recently came back about 2 weeks ago. Ive heard of people being able to fix these problems by either installing a transgo shift kit or upgrading / getting a new valve body. Anyone else have this problem or know what it may be or how to fix it?
Old Aug 25, 2015 | 05:39 AM
Giantkiller's Avatar
The "banging" when you put it in gear, may be the fwd engine mount. Mine is doing that, and the rubber isolator has deteriorated, and the connecting bolt is going metal to metal. Get under your car and inspect the mount. It's aft of the radiator and centered in the middle of the engine/transaxle towards to bottom.
As far as your transaxle...IDK. I'm not very transaxle/transmission savvy. I just know that the banging should not be coming from your transaxle, and you're not leaving pieces in the street.
Old Aug 25, 2015 | 12:29 PM
Costee's Avatar
https://maxima.org/forums/6th-genera...ssion-fix.html
Old Oct 18, 2015 | 10:51 PM
Cameron2006max's Avatar
Lakersallday24, have u solved your trans problems? Just curious because i also have a 06 SE with 157000 miles. Its in the shop now over trans trouble. Started with the lag between Rev and Drive and the hard shifts. Now it stops pulling when the fluid reaches operating temp, like its in neutral.. Just wondering what u found out on yours. I appreciate any and all info your willing to share.
Old Mar 8, 2018 | 01:43 PM
Shannon Strauss's Avatar
Jerkingi
I have an 04 maxima...its becoming a pain really love the car...1st it was jerking replaced bank1 camshaft w aftermarket from smythe automotive...then crankshaft from advanced auto...now car reads code that states I need vss...did not work input nor output....my CAR STILL HAS NO ACCELERATION AS IF TRANNY IS SHOT... ABS LIGHTS ARE ON BRAKE LIGHT IS AND SES... STARTS GREAT but wont drive anywhere.... A tread stated the vss code came up because its secondary to the abs speed sensor or wheel speed sensors... Speedo doesn't work either... Will changing or cleaning my wheel speed sensors fix my no go problem... I love how my car starts but hate how it will not drive.... As far as jerking goes... US MAXIMA LOVERS HAVE BEEN BAMBOOZLED W A PLASTIC TENSIONER GUIDE IN THE TRANNY IT WEARS DOWN AFTER SO LONG DROM THE CHAIN CIRCULATING AROUND IT
Old Mar 8, 2018 | 02:01 PM
Costee's Avatar
Your issue certainly revolves around a malfunctioning ABS unit. Have it scanned by a capable tool.
Old Feb 21, 2019 | 10:21 AM
Gabriel Lara's Avatar
Fixing problem
I would try your speed output sensor that should probably fix the problem
Old Mar 17, 2019 | 05:40 PM
mickey05's Avatar
There are to camshaft sensors. One in front and one in the back. Both are easily changed. After changing the transmission, I still had the same problem. Replaced both camshaft sensors and transmission works like new.
Old Mar 19, 2019 | 06:04 AM
04maximas's Avatar
the banging is coming from 1 if not all damaged motor mounts, the trans shifting issues to start with, check the condition and level of the fluid, if its brownish and low ya may wanna take it into a overhaul as its overheating and the clutches inside are burning the fluid, if its full and pinkish red than when was the filter and fluid last changed? if not sure and ya had car over 30,000 miles go ahead and change both the filter and fluid
Old Mar 13, 2020 | 10:01 AM
jessemofojones@gmail.com's Avatar
Just changed my tranny out for same issue
It’s still having the banging problem I got 87k on it. What’s the ultimate way to fix this? What’s the way my crap won’t break
Old Mar 13, 2020 | 05:41 PM
mickey05's Avatar
05 maxima shift problems
here's my two cents. I just replaced my trans with 98,000 miles on it. Bought a reubilt one and still had shifting problems. A little research showed there a 4 sensors on the the car that affects the trans. Two are the ones on top. There is another on the bottom of the trans, and one on the drivers side. I replaced all of these and my car has been shifting great. If you look a on the drivers side about halfway up at the rear you will see it. Don't know if this will work for you, but I now have a spare transmission because I listened to 3 trans mechanics,
Old Mar 13, 2020 | 06:08 PM
Thanks bro imma let my mechanic know appreciate you
Old Apr 1, 2020 | 09:40 AM
Munoz26's Avatar
Do you happen to know the part number or name of the sensors?
Old Mar 20, 2024 | 11:22 AM
Beverly Russell's Avatar
My 2006 nissan maxima will go in reverse but when I put it in drive it will go but won't shift
Old Nov 7, 2024 | 07:31 PM
Pspencer75's Avatar
Transmission issues
Hey guys I figured to reach out about my 06 maxima it shifts from 1st to 2nd fine but when it tries to go to 3rd it just over revs and doesn't shift. No weird noises just over revs. Could this mean the transmission is toasted or is it something else? Thanks in advance.
jtricer1973
19
Mar 1, 2014 06:09 PM
jmai86
Jun 24, 2005 02:08 PM
buntypatel
May 26, 2004 05:16 PM
Frank Rudisill
Nov 28, 2003 05:11 PM
Mr Ethiopian
Jan 21, 2003 06:03 AM
