Question on oil leak after oil change
Old Sep 9, 2015 | 06:31 AM
ag90fox's Avatar
Looking for some opinions. Recently changed the oil. Went with Mobil 1 5W-30 (previous 90K miles were on Nissan ester oil). Now I seem to have a slow leak/drip from the oil plug. I had made sure the bolt still had the brass(?) washer before putting it back in. Was able to tighten the bolt about 1/4 turn more after seeing the leak, but it's still dripping.
Heard some chatter that Mobil 1 was thinner than other oils. Could this be the reason for the drip? Should I dump the Mobil 1 and go with something else (same chatter indicated Pennzoil was better)?
Thanks!
Old Sep 9, 2015 | 06:39 AM
monty0620's Avatar
oil change
here at ryan nissan we change out the copper gasket every oil change your not suppose to reuse the old one
Old Sep 9, 2015 | 08:21 AM
gurule92's Avatar
Which Ryan Nissan do you work at?
Old Sep 9, 2015 | 09:00 AM
monty0620's Avatar
nissan
ryan nissan of minot
Old Sep 9, 2015 | 10:33 AM
MaximaDrvr's Avatar
Yep, try a new washer.
Old Sep 9, 2015 | 10:36 AM
LtLeary's Avatar
Originally Posted by ag90fox
Looking for some opinions. Recently changed the oil. Went with Mobil 1 5W-30 (previous 90K miles were on Nissan ester oil). Now I seem to have a slow leak/drip from the oil plug. I had made sure the bolt still had the brass(?) washer before putting it back in. Was able to tighten the bolt about 1/4 turn more after seeing the leak, but it's still dripping. Heard some chatter that Mobil 1 was thinner than other oils. Could this be the reason for the drip? Should I dump the Mobil 1 and go with something else (same chatter indicated Pennzoil was better)? Thanks!
You should replace the copper crush washer. When it gets completely crushed, it can't seal anymore.
Re Mobil 1 vs any oil... All oils at 5w-30 are the same viscosity when new. That is why you see common standards by the SAE and others certifying bodies. Otherwise you would not know if you were putting in some 3-in-one or 90w oils.
Old Sep 9, 2015 | 12:22 PM
monty0620's Avatar
new washer
washer number is 11026-JA00A nissan number
rtirbany
Sep 8, 2015 11:46 AM
carlosvq30
Aug 17, 2015 11:32 AM
acw
Aug 13, 2015 12:50 AM
acw
Aug 7, 2015 04:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
