Rear door handles on the front?
Old Sep 16, 2015 | 01:28 PM
ef9's Avatar
ef9
Hello, I have a question on the exterior door handles on the 4th gen. Will the rear door handles bolt-in with no modifications into the fronts?
I want to remove the door lock cylinder on the passenger side.
Old Sep 17, 2015 | 06:23 PM
DennisMik's Avatar
I tend to think they will, but why don't you measure them?
Old Sep 18, 2015 | 10:52 PM
Finkle's Avatar
I think they are different. The key hole makes me think the fronts are different
Old Sep 21, 2015 | 01:44 PM
Maxima_Joe's Avatar
4th Gen Parts King
They will physically fit but only one of the mounting studs line up. So you can either mount it with the one or fab up a bracket. I used just the one and it was never an issue.
Old Sep 26, 2015 | 11:10 PM
ef9's Avatar
ef9
Thank you for your response!
Old Sep 29, 2015 | 10:57 PM
Finkle's Avatar
Good to know.
My front passenger door is a junkyard door. I never got around to transferring the lock cylinder over from the old door prior to getting rid of it. so my passenger door uses a different key to open that I do not have. I might pull a door handle from a back door to get rid of the key hole that doesn't work.
I might be the only one, but I think it would look pretty cool to replace both front handles with rear ones. It would look cleaner with no key holes. Only issue would be if the keyless entry doesn't work, or the battery dies. Then you look like a bad parent for shoving your 5 year old through the pass thru hole in the truck to hit the lock switch.
Old Sep 29, 2015 | 11:29 PM
ef9's Avatar
ef9
This is a common swap on Hondas, to use the rear door handles on the front. In essence, a cheap shave for the key lock cylinders.
If it was a pure bolt-in, I plan on doing just the front passenger for now, and may think of doing it with the front driver too.
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
delerium75
Aug 19, 2015 11:08 AM
