Moisture In Untouched Fog Lights
Bob - Can you send a link to the bulbs that you bought? It still could be a manufacturing problem so if you are using a different brand then maybe this will solve everyone's issue.
Oops let me clarify! I TRIED installing the JDM led fog lights that some people did on this forum but for some odd reason they wouldn't work. So I returned them. I bought some different fog lights this time but haven't had the time to try and install them. They are halogens but they are 5000k and look promising quality wise *crosses fingers*
Anywho even having messed with the fog light housing, no condensation has formed thus far is all I'm saying.
Oh, and hurry up and get them installed and let us know how they work out.
Thank you very much. Thanks for the picture, too. Can you post the web site you used to order them?
http://www.lightinthebox.com/xencn-h..._p3308118.html
Code Scare7LITB gets you 7 bucks off at checkout.
I have my first 5k oil change this Thursday. I have about 6 different things for the dealer to look at. This will be one of them. What you did with the OEM bulbs is exactly what I was planning on doing. Should vent much better with the hotter temp bulbs.
Moisture issue
I too have washed my 16 quite a few times....brushless only so far and have driven n rain on occasion and have not had this problem. I also have changed my stock bulbs to LED bulbs. I did use the stock o ring that came with the original bulbs. So far no issues with moisture.
I can tell you that while I drove my S model before totaling it, my fog light came off bumper, like the screws were loose and it was just hanging there behind the bumper, also the front bumper on the left got detached from the frame. But all was covered under Nissan, so if you have any issues they would gladly fix them for you, they had to flat out replace my light since it was damaged behind the bumper...
I got a call a couple days ago from Nissan Consumer Affairs and had a bunch of questions for me about my fog light moisture issues. He said to take it back to the dealer again if I have issues and demand they replace them. If they wont to give him a call and he will take care of it. Nice to have that number in your back pocket. He said they were gathering information for their engineers. Sounds like others are complaining too. I urge you to let Nissan know if you are having the same issue.
I have a very slight moisture build up on both fog lights on the upper corner with it being 20 below out where I am I figured something like this would happen but I'm also a tech at Nissan that gets paid to do my own warranty repairs so I'll be changing them out this summer I already changed a driver front door speaker because the sound was coming in and out. One of the benefits of being a Nissan tech and owning one
I have recently noticed a lot of condensation in my fog lights and I have yet to do any mods to them. I called the dealership today and they said that all of their light housings have vents in them and condensation is normal. After 30-45 minutes of being on they should clear. I said that sounded like BS and he said that if they were pooling with fluid then that would be out of the norm but a little condensation is normal.
Still I call that BS....
I'm beginning to believe that an occasional small amount of thin mist in these fog lights might truly be considered normal. They are designed with vents for exactly that reason. I was looking at the manual for my wife's 2012 Explorer the other day because I'm going to install new bulbs in her fog lights, and it specifically states in her manual that an occasional "fog" of condensation is normal depending on the temperature, humidity, etc. and that it will burn off when the lights are activated. It then states that the housings are vented to allow for evaporation. It did point out that if there is enough condensation that it runs down the lens or pools in the housing, then there is an issue.
There are many reports on the forum of people changing their fog light bulbs and then having condensation issues, but I'm thinking that they would have had condensation anyway. I changed mine right after I got the car. In retrospect, I wish I had waited to see if there would have been condensation before I replaced the bulbs. After I replaced them, I had some condensation in one housing that eventually cleared itself. I have driven the car in all sorts of weather in all temperature and humidity levels and have not had any further condensation. The real question is why are fog lights more prone to condensation than headlights. If the headlights can be designed to not experience condensation, you would think the fog lights could be designed that way as well.
If you are having enough condensation that it is running down the lens or pooling in the housing, I would definitely make the dealer do something because that amount of condensation is not normal.
Frank Fontaine
Oct 30, 2015 06:13 AM
