1995 maxima takes forever to warm up
Old Nov 1, 2015 | 09:20 PM
sethh95max's Avatar
My car takes way to long to warm up.I can drive for 30 minutes or longer and it's still doesn't even make it to regular operating temp.I think it's the thermostat but not sure.anyone got any other ideas on what it could be?
Old Nov 1, 2015 | 09:50 PM
bumpypickle's Avatar
Usually a bad thermostat will cause the engine to overheat, and prevent hot air from coming out when temp is set to hot. Are you having these issues?
If not then the problem is likely your ECTS (Engine coolant temp sensor)
Edit: when you say it takes forever to warm up, do you mean the heat takes too long to get hot, the coolant gauge takes long to reach the middle or your engine and trans take a while to warm up and operate efficiently?
Old Nov 2, 2015 | 04:49 AM
njmaxseltd's Avatar
Replace the thermostat. As they age, the bimetallic spring gets weak and opens early.
Contrary to the last post, T-stats, installed correctly, are designed to fail open or cold as they get older. Make sure you install the new thermostat so that it opens in the direction of the water flow.
Old Nov 2, 2015 | 05:21 AM
sethh95max's Avatar
It take the temp gauge awhile to get to normal operating temp.and yea I was thinking it that the thermostat was starting to open to early.and I will.
Old Nov 2, 2015 | 07:32 AM
Crusher103's Avatar
T-stat or your temp sensor has gone bad. One of the 2.
Old Nov 2, 2015 | 12:38 PM
JvG's Avatar
JvG
If your heater works the problem is the sensor. If you have no heat it's the thermostat.
Old Nov 2, 2015 | 04:20 PM
jholley's Avatar
Another false statement in this thread!
Coolant will always flow thru the heater core when you turn the heat switch on. The thermostat allows the hot coolant to flow thru the radiator.
As stated earlier it's either the thermostat or your coolant temp sensor. I'm leaning on the thermostat.
Old Nov 2, 2015 | 05:32 PM
JvG's Avatar
JvG
Please tell me what is incorrect about this statement. A thermostat which failed in the open position will result in an engine that is too cold. The too cold water will mean a cool heater.
So what makes the Maxima any different?
You are thinking thermostat. I am too.
Old Nov 3, 2015 | 08:12 AM
dwapenyi's Avatar
And make sure the jiggle valve is on TOP!
Tequila
Dec 6, 2015 08:29 PM
imported_Nismo_max
Nov 1, 2015 05:21 PM
who4ever
Oct 31, 2015 02:05 PM
rkspec
Oct 27, 2015 09:42 AM
rbaker100
Oct 26, 2015 08:00 AM
