98 5spd just purchased
Old Nov 4, 2015 | 03:21 AM
blkmax1's Avatar
Got a 98 with a blown head gasket...The body has 192k but I want to add energy suspension bushings to the car, motor mounts etc, while I have the motor out, clean the engine bay...What other things can I do to bring her back even better than before...
Old Nov 4, 2015 | 04:06 AM
coskuntarik's Avatar
cleaning egr tube and idle valve air control
timing chain control
water pump and oil pump
pipes and gaskets control for lot leaking oil and water
There is thousands of things you need to check before you put on your car.
Your question is so general.
Old Nov 7, 2015 | 07:44 AM
JvG's Avatar
JvG
Water pump, fuel injectors, knock sensors while you are there, water hoses near the firewall which will be hard to change later on. Basically anything critical to operation, which is easier to do with engine out of the car. Change all fluids.
I strongly recommend replacing the clutch unless it has been replaced recently.
Make reliability your goal, followed by performance goodies should you still have money after all that.
Old Nov 7, 2015 | 09:15 AM
Dave20's Avatar
Can I bring mine by you..lol..I have to change the seals...
Old Nov 7, 2015 | 07:26 PM
ef9's Avatar
ef9
Easiest one to replace since you have the engine out (not sure if the transmission is out too), is the rear main seal. This seal requires the transmission to be removed.
All of the above stuff is a good idea too.
Old Nov 9, 2015 | 11:01 AM
JvG's Avatar
JvG
ef9 is absolutely right. A leaking main seal can make a mess, and cause clutches to slip.
The seal is easier to change now than it will be later on.
It is good practice to change the rear main seal when the transmission is removed for service.
Old Nov 9, 2015 | 11:06 AM
blkmax1's Avatar
Thanks guys for all the advice! I'm surely going to change the rear main seal, crankshaft seal, valve covers, water pump, some tensioners,various hoses & also vacuum lines. Any other suggestions?
Old Nov 9, 2015 | 02:21 PM
JvG's Avatar
JvG
Just for clarification.... You are planning on swapping engines rather than tearing your engine apart to replace the headgasket.... right???
Old Nov 10, 2015 | 05:49 AM
blkmax1's Avatar
Yes correct... I just want to replace as much parts on a budget that I can before installing the new motor
Old Nov 10, 2015 | 10:38 AM
JvG's Avatar
JvG
Since the uim will come off, you might as well get the injectors serviced and rebuilt.
They tend to leak and cause problems. Actually a little piece of plastic on the tip cracks.
Cleaned injectors mean a smoother engine and a little higher mileage.
You are doing a lot of preventative maintainance at this time. Good idea while everything is accessible.
Old Nov 10, 2015 | 11:20 AM
blkmax1's Avatar
Thanks alot... it'll be my winter project, taking my time and doing it right
Old Nov 12, 2015 | 10:03 AM
blkmax1's Avatar
What are some upgrades I can do while it's sitting, such as interior, engine bay, electrical etc. I'm looking to make this one of the cleanest, most reliable Maxima around...! Future plans are the radiator support, Es mounts & whatever bushings I can get & full front end rebuild.
t6378tp
Dec 2, 2015 12:42 PM
t6378tp
Nov 11, 2015 04:45 PM
Dolphinride
Nov 8, 2015 07:00 PM
who4ever
Oct 31, 2015 02:05 PM
Icykilla1
Oct 30, 2015 08:03 PM
