Transmission 1 to 2 is tough 2-3-4 is soft
Old Nov 18, 2015 | 07:42 AM
coskuntarik's Avatar
What can I do for this issue ?
1 to 2 is tough changing but the others 2-3-4 is soft
Any ideas ?
Old Nov 18, 2015 | 03:13 PM
maxima297's Avatar
Any ideas ?
Mine was like that until I had the clutch replaced.
Old Nov 18, 2015 | 07:19 PM
JvG's Avatar
JvG
I think our Turkish member has a four speed automatic transmission.
If so, he should use the search feature and look up automatic......
Other members have posted about this problem in the past, if I recall.
Old Nov 19, 2015 | 03:24 AM
Yes it is automatic, like what you said, İ have read some past posts and learn about transmission resistor can cause this hard shifting.
İs this okay with my 2.0 liter maxima ? Should I change this ?
Are these same part because it looks like that ?
A15 000L00 7626 (This is what İ have now )
31037-71L00
Old Nov 19, 2015 | 11:08 AM
JvG's Avatar
JvG
Do you have the 4 cylinder engine?
I'm thinking that you may have different transmission parts as well.
We on this forum are far from experts. Just a collection of people who help each other and share what we know.
Old Nov 19, 2015 | 11:22 AM
I have the V6 2.0 Liter 24 Valve 140 Hp by the way you can see my car photo of my last post about low rpm. I have installed there. I want you too look at it.
Old Nov 19, 2015 | 02:14 PM
JvG's Avatar
JvG
Your car has a different engine than what most of us have. it is also intended for a different market. It is possible, even likely, that not all parts will be exactly the same. Specific parts,such as inside an automatic transmission might have different part numbers in Turkey than in the USA.
Some auto parts search engines ask which country you are in.
Old Nov 20, 2015 | 01:24 AM
İ need to ask automatic transmission resistor to my Nissan service for my hard shifting, what I saw in photos where is that located I have that part exactly same but the code on it is different.
Thanks anyway appreciate for all helps.
Old Dec 2, 2015 | 09:32 AM
Quickywd01's Avatar
Solenoids for shifting are worn or the clutch packs inbetween the gears are worn. Exchange fluid for full synthetic about 10 liters. Also add an external automatic transmission fluid cooler.
Old Dec 3, 2015 | 04:15 AM
what kind of external cooler can I use ? Universal or custom fit ?
Old Dec 3, 2015 | 11:59 AM
DennisMik's Avatar
The number that you found on the resistor (31037-71L00) is the same for the U.S. cars. You can measure the resistance of the resistor with an ohm meter. It should measure between 10 and 15 ohms. I think that the resistor is OK because all gears would shift hard if the resistor was bad.
If you are going to use a transmission oil cooler, it is your choice for custom fit or universal. They would both work equally well. Custom fit would be easier to install but would probably cost more money.
If you would like to look up part numbers for your car, here is a link:
http://nissan4u.com/parts/maxima/
The resistor is on this page:
http://nissan4u.com/parts/maxima/er_...llustration_1/
Old Dec 3, 2015 | 09:00 PM
Quickywd01's Avatar
Bar and plate designed for auto trans. They have a bypass for when the fluids too cold. Tube and fin is better than nothing.
Old Dec 5, 2015 | 02:51 AM
Thanks for all information, is there any part number for custom fit or any advice for universal one ?
Old Dec 11, 2015 | 09:03 PM
KRRZ350's Avatar
Low engine performance really causes a noticabley mushy shift in the re4f4o. Knock sensor will do it big time
Old Dec 12, 2015 | 10:14 AM
I have changed the knock sensor with oem 5 months ago :/
pieterm
23
Dec 15, 2015 01:52 PM
bperryman21
Nov 17, 2015 11:57 AM
2016maxsr
Nov 3, 2015 03:29 PM
brichi
Nov 1, 2015 06:40 AM
monty0620
Oct 22, 2015 07:11 AM
