metal-on-metal grinding noise when turning left
Whenever I am driving and I turn left, the car makes this bizarre sound that sounds like metal is grinding on metal. Imagine if somebody took a cowbell and threw it like a football and you heard the cowbell ringing very fast. That's what it sounds like (weird analogy, but best way I can describe it). Could it be a CV joint? Thanks.
Brake rotor shield is bent inwards touching rotor upon hard cornering. Stick hand in wheel gaps or behind and bend shield back and away from the rotor a little using your palms is best. Good luck.
This may sound stupid, but do i need to take the wheel off to get to it, or the brakes? Also, how will I know what the brake rotor shield looks like?
Could be a shield, a CV joint, or a wheel bearing. Has anyone been under the car recenly, or have you hit debris in the road? Does the noise come from the right side when turning left?
Derrick2k2SE
Dec 30, 2015 11:45 AM
Dab
Dec 25, 2015 02:11 PM
solariis
Dec 22, 2015 08:12 AM
2kmist
Dec 15, 2015 05:13 PM
