Nistune tech ?
Old Feb 22, 2016 | 02:31 PM
crewchief264's Avatar
Nistune tech ?
I just finished installing a new engine and was working on the initial start up. I updated nistune just yesterday. (nistune was previously installed and operating fine)
I had a fuel line leak and my cam sensor connector was loose and all this time I was getting normal fuel prime. Fired the car with an old map and it started right up but died before I could get the K constant adjusted.
I had to leave for an appointment. When I came back and started at it again I had no fuel prime. I checked the pump, and it operates. I dont have voltage at the tank. I pulled the fuel relay and its good to go. I checked the power and ground coming to the relay and I am not getting an ecu signal to the relay....
Any ideas?
Old Feb 22, 2016 | 05:43 PM
akurtzer57's Avatar
When you turn the key on does the check engine light up or see lights turn on on side of ecu?
shodog
Feb 16, 2017 01:38 PM
homeofbacon
Jan 5, 2016 10:42 PM
Maxboy23
Dec 8, 2015 03:41 PM
kingkai1990
Dec 8, 2015 10:20 AM
Lowered_a33
Dec 7, 2015 11:36 AM
