checking oil levels!!
Old Mar 11, 2016 | 09:31 AM
followthadollar's Avatar
i need help from you guys... my engine oil dip stick is fully covered in oil and makes it impossible to get a reading..
i have an oil leak coming from the rear valve cover which i will patch up soon.. in the meantime i want to be on top of my oil..
Old Mar 11, 2016 | 09:55 AM
Turbobink's Avatar
Stop checking your oil with the engine running ...
Old Mar 11, 2016 | 10:02 AM
Hopefully you're doing the following:
Waiting at least 30 minutes from time you shut car off.
Pull stick and wipe it clean
Re-insert and make sure it's fully seated
Pull stick out again and get a reading
Old Mar 11, 2016 | 10:37 AM
maxima297's Avatar
And don't check it immediately upon shutting the car off.
Old Mar 11, 2016 | 11:33 AM
Dave H.'s Avatar
or just check it after it sits overnight...
Old Mar 11, 2016 | 11:35 AM
Thank you all .. What is the proper way to check the oil pressure?? Is there a thread for that?
Old Mar 11, 2016 | 11:41 AM
M in KC's Avatar
You will need a remote pressure indicator as what is installed from the factory is just an idiot light triggered from the pressure sensor near the oil filter housing. The absence of oil icon illuminated on your instrument display would indicate oil pressure within the allowable pressure range or the bulb is burned out.
Old Mar 11, 2016 | 11:45 AM
Ok .. Or I can perform an oil compression test right?
Old Mar 11, 2016 | 11:48 AM
M in KC's Avatar
It's not really an oil compression test as you can't compress a liquid. It would be a cylinder compression test to evaluate the health of each cylinder compared to a baseline value.
What are you attempting to determine.?
Old Mar 11, 2016 | 02:41 PM
JvG's Avatar
JvG
Unless the oil light flickers at idle, there is not much reason to worry about the oil pressure. Not much you could do much about that anyway.
Old Mar 11, 2016 | 09:21 PM
LJay's Avatar
My oil pressure sensor was unplugged & I didn't check the dip stick & ended up ruining my engine last year. Now with a new engine, I check my oil religiously.
Old Mar 11, 2016 | 10:09 PM
CS_AR's Avatar
When in doubt about oil pressure, I use a test kit that I bought at Harbor Freight some years ago. I see the same unit is now less than $27.
Be careful to use a fitting for pressure testing that is like the sending unit's. IIRC the stock sending unit uses 1/8" British Standard Pipe Thread (BSPT). I don't think I needed an adapter with the kit that I purchased.
http://www.harborfreight.com/engine-...kit-98949.html
I use the following socket when working with an oil pressure sensor.
Old Mar 11, 2016 | 10:47 PM
bumpypickle's Avatar
15 mins after engine shut off and you should get a decent reading. As for oil pressure, I wouldn't worry about it. Just make sure your topping off your fluids. I check each fluid at the beginning of the week and refill as necessary.
Old Mar 12, 2016 | 05:55 AM
Very good tips thanks everyone..
Old Mar 12, 2016 | 10:32 AM
JvG's Avatar
JvG
L.Jay, I remember your problem . No oil light at all, and not checking levels.
I mentioned flickering at idle...... yes, I assume he has a functionin oil light. Maybe I should not assume anything. Thanks for pointing that out. Sometimes I forget how old these cars are.
Old Mar 12, 2016 | 01:35 PM
Malfunctioning light or not, it's bad to let the oil get to the point where it triggers the indicator. Besides, these are old cars and almost all of them that haven't been cared for will leak oil, like most older cars. It should already be mechanically inferred when buying a vehicle with age like this that you would need to check fluids frequently
Old Mar 12, 2016 | 02:00 PM
LJay's Avatar
Yeah I know. Accidents happen. It's my first car but I've learned a lot since then about it. I fixed everything (with the help of the .org) & now there's no check engine light, recently passed smog so now I can enjoy my car!
reallywildstuff
18
Oct 29, 2019 10:09 PM
edwardh1
22
Apr 14, 2016 12:05 PM
KingLwood
Mar 16, 2016 04:40 PM
maxinout93
Mar 13, 2016 07:36 PM
brichi
Mar 7, 2016 09:55 PM
