CRAZY noise on startup?! Help!
Old Mar 23, 2016 | 08:12 AM
GLB07's Avatar
02 Max SE, 147K. About a year ago, during cold starts or if the car has been sitting a few days it makes a crazy like rattling noise for 5 seconds then goes away. It happens every blue moon when warm.
I've had my car for 6 years. routine oil changes etc. I took it to my local Midas, of course no help, they said my engine was done which I'm having a hard time believing. No problems after the noise, runs fine, no CEL's, no hesitation etc.
I recorded the noise to the best of my ability. Check it out. I need help on diagnosing this noise!
File Type: wav
Old Mar 23, 2016 | 09:34 AM
mclasser's Avatar
Recording was too short but could be the timing chain rattling. A video of the noise with the hood up will be more helpful.
And don't go to chain shops like Midas.
Old Mar 23, 2016 | 10:44 AM
GLB07's Avatar
I tried to get a better recording but it is literally as short as the audio clip was. Funny you mentioned the timing chain - i was thinking the same thing.
I will try to get a longer clip but will probably have to wait as it doesn't make the noise on every start up
Old Mar 23, 2016 | 10:47 AM
Child_uv_KoRn's Avatar
Bad *** Newb
That's exactly what it is.
The tensioner is bad, but since they don't sell the old design (revised due to the failing guides/tensioners on the newer VQs), you'll just have to find the correct O ring for it (it's just a piston in a cylinder with an O ring to seal it).
another edit: idk what size
Old Mar 23, 2016 | 10:50 AM
GLB07's Avatar
The tensioner is bad, but since they don't sell the old design, you'll just have to find the correct O ring for it.
Maybe someone on here has done this and knows.
thanks for the help! it was driving me crazy! and i wanted to get it replaced before anything happened.
Hopefully someone can find the correct O Ring and post a link for me. thanks again!
Old Mar 23, 2016 | 11:15 AM
NmexMAX's Avatar
dot dot dot ...
How's the oil level?
Old Mar 23, 2016 | 11:37 AM
GLB07's Avatar
Oil level is good. I just recently had it changed. I noticed the noise length did get shorter when it was changed.
chevyman1980
Jan 27, 2016 04:02 PM
McJonny
Jan 19, 2016 11:42 AM
slim chance
Jan 15, 2016 10:53 AM
MAXIE06SE
Jan 12, 2016 08:26 PM
