rusted lower tie bar creates costly repairs
I had a question directed to some of the other Maxima enthusiasts regarding the issues with the 5th Generation.
If the engine mount shorts out the ECU after an IACV replacement could that be from the lower tie bar being rusted? If the lower tie bar is rusted at the point where the under plate ties into could that be some of the reason why the engine mount shorts out the ECU? Both engine mounts are attached to the under plate.
I had that issue however Nissan did not mention the under plate being attached to the lower tie bar in an area that has badly rusted. I didn't realize the under plate that is bolted to the rusted tie bar until I began to work on the thing myself a few months ago. I had been taking it to several garages for service throughout five years. I decided to re seal the oil pan when I realized the engine mounts were actually attached to the under plate I mentioned above.
correction: Nissan informed me that the Engine mount shorted out the ECU which in turn shorted out the IACV motor.
How else would the engine mounts short out an ECU unless there were issues with stability?
IACV shorted out from the coolant, I'm sure. Dealers = dee dee dee
did they show you the shorted ecm and did you have issues with your idle?
the car was acting up and the MIL lamp came on. It was downshifting. I wouldn't accuse Nissan of being wrong or not being accurate with their diagnoses. They are the ones that sell these cars. I'm not in any position to compromise their findings. No I didn't see the old ECU however I would assume it was burnt out and went out with the garbage the next day.
You may be right on that, but maybe not. Nissan stopped making the ECU a few years ago, so what you buy from a dealer now-a-days is a rebuilt unit. And guess where they come from. The same goes for alternators and starters and a few other things.
I've pulled the old Nissan service invoice from my file. It was a remanufactured ECU 1@918.58. This was back in March of 2011. The vehicle had 118,000 miles on it then.
The previous garage charged me 630.92 for IACV install + diagnostics. Problem was they refunded me $300 back because they said they didn't have a Nissan computer to re-learn the ECU. When I got the Vehicle to Nissan they removed the IACV that the previous garage installed and re-evaluated the situation. That's when they informed me the ECU + IACV was bad.
I initially tried to take it to a dealership alternative because of that but they couldn't handle it.
Now I find out years later that Nissan informed me that the electronically controlled mounts shorted the IACV out. I was completely confused for years. I eventually obtained the Nissan engineer circuit specs and went through it. No way!
I'm ultimately concluding that coolant from the throttle chamber shorted out the IACV circuit + Driver. There was some confusion because I had O2 sensors installed just weeks before and the garage didn't perform the reprogramming.
Now when I flush the coolant every five years I'm going to carefully remove/clean the throttle and re-seal the chamber.
Coolant in the TB is a giant joke. Maybe once upon an engine many years ago, it could freeze up due to sneaky physics of sucking air lol
That's funny, I was just looking at the car from the side yesterday and thinking the brakes look so small. They're on my list at some point but I'll probably wait till the 6th gens start showing up in the local U-pull it yards.
I only know because I have one of each and just replaced it proactively on my 315,000 mile 2000.
Dude was driving so fast he snapped off the control arm cleanly and put hole through to the interior. I had to pick the whole arm and wheel up out of the back seat and remove the caliper
valerit1
May 19, 2016 04:13 PM
JoeyChrome
19
Feb 27, 2016 02:49 AM
Sam Maxima
Feb 17, 2016 06:31 AM
