Please help! Crank sensor!
Old May 26, 2016 | 03:55 PM
baumli17's Avatar
I have an 03 maxima with 6 speed tranny, I replaced the crank sensor bc the code was on. After it still didn't start very easy so I unplugged the sensor and it would start then I plugged it back in and the tach would come back on. But if I clear the code it wouldn't start until I unplugged jt again. So I assumed the flywheel was miss aligned, pulled the tranny and its lined up. But the timimg gear is pretty banged up and looks like it got hit with a ginger a time or two. So my question is do you think I need to replace the flywheel replaced?
Old May 26, 2016 | 04:19 PM
Child_uv_KoRn's Avatar
Bad *** Newb
The timing ring can't get banged up by itself. If it worked fine before, then it should still work fine if the sensor is good. I think the replacement sensor is junk.
Take a picture of the ring, I'd like to see it. It can almost fall off and it'll still work fine (I know, mine was barely held in by a couple screws on the fidanza).
Old May 26, 2016 | 04:35 PM
baumli17's Avatar
Someone put the wrong oil pan on so they tried grinding a new hole in the tranny and hit the plate in the process
Old May 26, 2016 | 05:27 PM
Bad *** Newb
Looks good enough to work to me. I'd return the sensor and either get oem or one from napa (haven't had any trouble with their cam sensors).
Old May 26, 2016 | 06:21 PM
baumli17's Avatar
Im lost on this how do I know if this is the original engine or original tranny or if the placement of the crank sensor is in the right spot and why would it read for the tach but not for the ecm?
Old May 26, 2016 | 06:43 PM
Bad *** Newb
Wait, you bought it like this?
It can't be misaligned b/c of how it fits into the oil pan/tranny case.
It does sound like the motor has been swapped if they left on the wrong oil pan.
Old May 26, 2016 | 07:06 PM
baumli17's Avatar
Yeah it had an oil pan where the sensor came in on the bottom but I changed it to an 03 oil pan so it comes in close to the starter so now I'm confused on to why it'll read on the damn tach but not ecu, unless the engine was right snd they swapped trannys, thats why I wanna find out what is the correct motor and tranny
Old May 27, 2016 | 05:50 AM
Prophecy99's Avatar
hard to say about napa sensors, i just replaced my napa one with oem on monday, just saying.
Old May 27, 2016 | 09:42 AM
baumli17's Avatar
I ended up welding the bad spots back up and grinding them smooth just to be sure now gunna put it back together, if that dont work I guess I'll try replacing the stupid sensor again
Old May 27, 2016 | 11:06 AM
nestorlugo's Avatar
Why not just finding a new (used) one to rule it out as a potential suspect? After all it's already out
Old May 27, 2016 | 11:41 AM
baumli17's Avatar
I have been looking and looking but a new one is 400 im not doing that
Old May 28, 2016 | 10:50 AM
baumli17's Avatar
Well for anyone who has been wondering or following along. Got it put back together and started right up. Now threw a random misfire on cylinder 3 so I'll be replacing the coil. Soon
Old May 28, 2016 | 10:56 AM
Bad *** Newb
Did you change anything?
Old May 28, 2016 | 08:43 PM
baumli17's Avatar
Nope, now I got rid of the misfire by a new coil but I still have a bog or cut out at mid rpms
Old May 29, 2016 | 03:57 PM
nestorlugo's Avatar
Oem coil?
Old May 29, 2016 | 10:15 PM
baumli17's Avatar
No I bought it at oreillys it was like 60 bucks with lifetime warrenty, im not sure if a battery that wont hold a charge is the problem or part of it
Old Jun 2, 2016 | 03:24 AM
baumli17's Avatar
Ok so I while running through the rpms while in neutral or even driving at about 3500 rpms my car will fall on its face just for a split second and continue reving up and then again in the higher rpms. If running at a constant rpm around 3500 rpms it will just cut in and out. I have no codes except a p0447 evap circuit
illvillecat99
23
Dec 4, 2016 01:57 PM
Jose Flores
Mar 3, 2016 04:40 PM
Maxima50
Mar 3, 2016 07:49 AM
Lovemyi30
Mar 2, 2016 08:28 PM
