Aftermarket Cam/Crank Sensors?
Old Mar 1, 2016 | 05:37 AM
Maxima50's Avatar
Starting a new thread on this since I'm having problems with my Max. I replaced both the Cam/Crank sensors (I bought generic non oem), cleared the codes only to have my car die again. Same symptoms before replacing sensors, car starts bucking and then it just dies. I pulled the code p0035 again. Could these cheap sensors be bad alresdy? I'm scared to drive my car anymore.
Old Mar 1, 2016 | 01:16 PM
Montego Murph's Avatar
Could be bad sensors. Or it could be the harnesses leading to the sensors. Get out your continuity meter and do some checking.
I also like to clean the hell out of the connectors with a generous WD40 bath when I change connectors. Works as a good low-impact solvent and the remaining film keeps moisture out (whod'a thought)
Old Mar 2, 2016 | 07:28 AM
Prophecy99's Avatar
this is what is suspected of early CPS failure, yet I have aftermarket napa ones and it cleared my issue since for 2 years now (didn't have one code though , just car shutting off with no warning while driving 45 mph and then more and more untill it didn't start up)
Old Mar 2, 2016 | 08:11 AM
Child_uv_KoRn's Avatar
Bad *** Newb
I have used napa sensors, too.
Old Mar 2, 2016 | 10:18 AM
Maxima50's Avatar
I bought these from Amazon, not sure on the brand. I'm going to get some electrical spray and clean out the connectors next.
Old Mar 2, 2016 | 10:27 AM
maxinout93's Avatar
does anyone know how much the cam pos sensor is at the dealer? I have a friend that just bought a 03 maxima and says he changed both cam sensors with autozone brand and still has issues starting the car.
Old Mar 2, 2016 | 10:39 AM
Bad *** Newb
cuz junkozone or it's the crank sensor
Old Mar 2, 2016 | 03:32 PM
maxinout93's Avatar
Yeah thats what i was telling him, that he needed to buy OEM only on those sensors but he didnt listen and now i dont know if he can return the parts with no box lol to get his money back and go with the oem parts from the dealer.
Old Mar 2, 2016 | 05:23 PM
Bad *** Newb
Or junkyard
Old Mar 2, 2016 | 05:32 PM
maxinout93's Avatar
Or junkyard
yeah good idea lol
Old Mar 2, 2016 | 05:48 PM
Maxima50's Avatar
I cleaned the sensor connectors and made sure everything was good and clean. Instead of driving I just let the car run. It may have run for 15 minutes then it died. Tried to start it numerous times and no crank. I'm thinking these generic sensors are no good.
Old Mar 3, 2016 | 06:14 AM
Bad *** Newb
Wait...what? No crank... You mean no fire?
Old Mar 3, 2016 | 06:23 AM
Maxima50's Avatar
No fire, the car doesn't start. The past few times after the car cools down it will start, but takes a while to fire.
Old Mar 3, 2016 | 06:53 AM
Bad *** Newb
Interesting. That's what the original, bad, cam sensors can do. Maybe someone cleaned them up and returned them haha
Old Mar 3, 2016 | 07:01 AM
Prophecy99's Avatar
you cant return even the slightest used electronic parts, i tried,
had same exact symptoms, closer interval between start ups had this problem, and eventually became worse and worse no matter how long it sat , the last time i could barely drive it one block to the mechanic because it was so bad, i have napa sensor now though and i only changed one sensor of the 2
Old Mar 3, 2016 | 07:49 AM
Maxima50's Avatar
The $11 front sensor (closest to front bumper) that I got from ebay has got to be the problem! I'm not going cheap on the next one I buy. A car dying while going down the highway is not cool.
slim chance
Jan 15, 2016 10:53 AM
bvb_09
Jan 5, 2016 07:22 PM
coskuntarik
Dec 24, 2015 12:00 PM
Govols83
Dec 16, 2015 09:19 PM
Montego Murph
Dec 14, 2015 01:41 PM
