Bend heads
Old Sep 20, 2016 | 12:51 PM
maxam's Avatar
Bend heads
Good day guys
Just wanted to know what should i do if i got my engine mixing oil and water and end up with bend heads.
Do they affect the cams?
Should i replace them?
Or is it ok to re machine them?
Old Sep 20, 2016 | 03:24 PM
JvG's Avatar
JvG
Originally Posted by maxam
Good day guys
Have you seen coolant in the oil, or oil in the coolant?
Have you done a block test? This helps determine if exhaust gas is entering the coolant system.
Did your car overheat? What make you think that you have warped heads?
Old Sep 21, 2016 | 06:29 AM
maxam's Avatar
I allredy opened the heads and found blown head gaskets.
Yes there was a milk when i opened the oil cover.
And there was some kind of foom coming from the radiator it looks like a saop foom.
And yes i got my car over heated unfortunately befor all of that.
My mechanic said that i have a warped heads.
Old Sep 21, 2016 | 10:56 AM
JvG's Avatar
JvG
Most of us would install a used engine at this point. Good ones are still plentiful and cheap.
Old Sep 22, 2016 | 12:10 AM
maxam's Avatar
What if it was modified with low compression pistons and rods and cams for turbo project ? of couse you dont want to loose that.
That is why im asking if its affecting the cams or not. I have a good block and pistons. But heads are bend and head gasket is blown.
Replace heads? Or re machine them?
MaximaNoob1
20
Oct 13, 2016 02:53 PM
97_GXE
Sep 20, 2016 02:37 PM
Dlowe90
Sep 16, 2016 11:55 AM
loudmaxi
Sep 16, 2016 07:25 AM
