New-ish member, need help
Old Sep 22, 2016 | 02:23 PM
Luckydekmax's Avatar
Looks like theres a place for **** to post finally. More than happy to share my knowledge, but i am at my wits end this time. So i have a 99' body, 01' full motor swap, running on a '95 comp. I picked the car up cheap with the intention of making it a DD, since it has new suspension, tranny, and motor supposedly only has about 90k. So car runs like crap, and i traced it back to the iacv. Definitely bad, but it only made the issue worse when i installed the new one. Its still running 01 injectors, 5th gen iac, crank sensor replaced, 97 computer was swapped with new iac, but problem got worse. Any ideas??????
Old Sep 22, 2016 | 08:36 PM
Update: so i put the '95 ecu back in and the car runs like it did before. Took it for a short drive. Enough to warm it up and let into the throttle a bit. It hasnt done the thing where the rpm's seem to lock into 2400-2500 rpm's (very hard to drive like this), but it still will NOT idle at all. I have looked and looked. People have fixed this issue with a crank sensor, a new maf, or new iacv/ecu. Ive done all of these, and the new parts all teat out exactly right. I know people have done this swap. What am i missing??? Do i need to locate a 4th gen LIM so i can use the 259cc injectors that the ecu is programmed for? I know people have run NA set-ups with the 290cc's on a 4th gen. Should I switch to the PF IAC? Please, i need to get this car running NOW, or i will have to abandon it. Any help, advice, or suggestions are greatly appreciated.
Maximus909
Aug 5, 2016 01:14 PM
maxima4826
Jul 25, 2016 08:31 AM
FrankyGeeLex
Jul 10, 2016 11:28 PM
Michael Stibbard
Jul 5, 2016 08:14 AM
jery2109
Jun 26, 2016 08:48 PM
