What is this hose?
Old Mar 26, 2017 | 01:37 PM
Shrout1's Avatar
What is this hose?
I saw this cracked and leaking hose when I was replacing my fuel filter. Gawd this car is showing its age.
Planning on light driving in the next two weeks... 5 mile commute to work. Should I leave her sit while I wait for a replacement part?
How hard is it to replace this hose? Looks pretty easy but looks can be deceiving...
Attached Thumbnails What is this hose?-img_8516.jpg   What is this hose?-img_8517.jpg   What is this hose?-img_8515.jpg
Old Mar 26, 2017 | 02:13 PM
sdunker's Avatar
Hose just pulls off. Last one I replaced I think I used reg. coolant heater hose. I believe it is just a breather hose between valve covers.
Old Mar 26, 2017 | 02:30 PM
Shrout1's Avatar
Ah. So it probably isn't impacting performance? It seems to be leaking oil.
Old Mar 26, 2017 | 10:15 PM
vqmaxman's Avatar
This hose your referring to it's a crankcase ventilator hose. It helps to keep the cams cool.
Old Mar 27, 2017 | 08:29 AM
DennisMik's Avatar
Yes, it is the crankcase ventilation hose. It is used to suck oil vapor fumes out of the engine via the PCV valve.
Old Mar 27, 2017 | 10:18 AM
flynlr's Avatar
14 bucks at most online dealers
this is for a 95 but may be same for others
11826-31U00
you can see pic here
https://www.infinitipartsdeal.com/pa...826-31u00.html
Old Mar 28, 2017 | 07:13 PM
Shrout1's Avatar
11826-31U00
Thanks! I'll probably order it.
Could this cause a vacuum leak?
Old Mar 29, 2017 | 02:22 AM
flynlr's Avatar
yes on the vacuum leak
Old Mar 29, 2017 | 08:02 AM
vqmaxman's Avatar
These vacuum leaks on this type of vent hoses will effect the motors performance. The improper breathing and cooling won't let your car run right.
Old Mar 29, 2017 | 01:14 PM
Shrout1's Avatar
Hmmm wonder if I'm blaming my MAF for something that this hose is causing...
Any tricks to replacing this hose? Doesn't even look like it's clamped on.
Just ordered it from the site you linked! Thanks! Hopefully it will get here before I have to go on business again :P
Old Mar 29, 2017 | 01:29 PM
vqmaxman's Avatar
It's obvious you have a problem, Maf,coils, injectors. I and many others have stated what the problems could be. I would start pulling away with the Maf first. I had the stalling or slight cutoff and hesitation at the red lights that was the Maf. The accelerations were also affected by the Maf. The next thing we should here, is that was the problem or you got it fixed.
Old Apr 1, 2017 | 03:29 PM
Shrout1's Avatar
Thanks! Switched the MAF out for the remanned one and the car just doesn't start at all now. Tried the OEM again and it didn't help. Chasing down the ignition issue in a separate thread
Also I replaced this hose - only took about 5 minutes, just had to wait for the part to come in. Now to see if it helps after the car starts...
