Peeps that have had Knock sensor probs..
how did your Max run and react when your knock sensor was bad? anyone care to unplug your knock sensor really quick and tell me how your car runs? please help me...ughh
A dead/dying Knock sensor will not be noticable in everyday driving. If the ECU does not recieve a valid signal from the KS, it will automatically retard timing in order to minimize the possibility of detonation. Even at WOT, the difference shouldn't be VERY noticable. At the track, however, it will. Just replacing the KS on my car made my 1/4 drop almost a second.
Originally posted by Y2KevSE
How so?
How so?
If you replace the KS, the ECU then gets a valid reading off of the KS, and no longer has to retard the timing, giving me full power.
Originally posted by medicsonic
I guess you didn't read my post then.
they are not that bright
Re: Peeps that have had Knock sensor probs..
i'm going to have to disagree with Medic on this one...
I did feel my topend get weaker when i had a bad knock sensor. once the car shifted into third i could feel the car get a lot weaker. i tested this at the track and also i ran a maxima with less mods then i had and sure enough he started pulling me at about 75mph ... matthel you said you were using a Snap-on scanner, that is the same one i use to trouble shoot my car. when i hooked it up to my car it showed the 0304 knock sensor error. if you are still not sure of the knock sensor then you can use the scanner to compare your cars timing to another maxima that you know has no problems. the scanner will show timing adv/ret at WOT and it should be nearly identical for all maximas ... i don't remember the exact number my when comparing the timing of my car with another maxima i saw my timing was show a lot of retarding ...
Ant
Re: Re: Peeps that have had Knock sensor probs..
you are kinda agreeing with him..
Ant
Ant
Ant
Ant
hummm
i dont think ill be able to compare to another Maxima for 2 reasons. 1 being i have a JWT ECU and it retards timing for my boost application. 2nd is i cant go WOT cause the ECU is retarding my timing so it wont go above 2k rpm. thanks for the suggestions...keep em coming.
The quote below is from another thread. HOWEVER it has a point in it I thought you might want to read.
"The clamps are a pain in the butt to get to. not only that, there is some solenoid in the throttle body that will cause the idle to stick at 2000 rpm or so, its a real pain. I suppose you could disable that solenoid, but I felt zero difference whatsoever."
Again , I do not know if this is correct, but given your current situation I am trying to help any way I can
Re: Wouldn't a bad knock sensor trip the CEL?
Originally posted by 1MAX2NV
Or does it only show up on scanner tools?
Re: Re: Wouldn't a bad knock sensor trip the CEL?
Wow...learned something new everything. So that was the problem with your car, how did you ever came to suspect the KS. What's the testing procedure to figure if it's bad or not?
According to the ESM, a bad KS is the only error code that will not trip the CEL.
Re: Re: Re: Wouldn't a bad knock sensor trip the CEL?
The testing procedure is in the Haynes manual. You find the connection for it in the wiring harness and probe it. Forgot wher my aynes manual is right now, or else I woud have told you.
humm i dont think its the knock sensor so i wonder what else there is to look at..
my03maxima
Jul 28, 2024 07:40 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
hehehehhehe
