So I guess I can't jack the car up from the front anymore
Old Jul 10, 2017 | 08:02 PM
mclasser's Avatar
I was changing my tie rods and put the floor jack at the usual jack point near the rad support. I heard some crunching and then a few flecks of rust fell down. Guess my rad support has gotten weaker. It has some rust spots but isn't as bad as the ones I've seen on here. The pinch welds on the rocker panel are also bent up but still usable.
Fun stuff
Old Jul 11, 2017 | 04:57 AM
SubwayVQ's Avatar
Fun stuff
Welcome to the club! I can still jack mine up from the rad support, but I can see a giant hole going right through it, so I'm not going to anymore. My new method takes longer, but I feel way better about it. Jack it up by the LCA bushings, then stick the jack stand on the pinch rail.
Old Jul 11, 2017 | 10:01 AM
maximatech12's Avatar
If you replace it you need a spot weld bit and cutting oil. 50 spots in all!
You could just bolt a new lower section in.
I take it the hood is real shaky too? because the hood brace is bolted to the front where it rusts the hood striker has no stability.
Old Jul 11, 2017 | 02:12 PM
mclasser's Avatar
Here's a crappy pic of the rust. This isn't too bad, right?
Old Jul 11, 2017 | 06:34 PM
DennisMik's Avatar
Put the jack under the lca and lift it up. I always put a piece of 2x4 on the jack to cushion the contact.
Old Jul 11, 2017 | 07:13 PM
SubwayVQ's Avatar
Looks like mine. As long as you don't jack the car up anymore by there, it should be solid enough to not cause issues. Is the support bracket for the hood latch still attached or has that broke free as well?
Old Jul 12, 2017 | 01:08 AM
Child_uv_KoRn's Avatar
Bad *** Newb
Long reach jack halfway back on the crossmember
Old Jul 13, 2017 | 04:27 AM
maxinout93's Avatar
How can you bolt the lower section in? I thought it was welded, just asking because im about to get someone to do mine real soon.
Old Jul 13, 2017 | 09:36 AM
Turbobink's Avatar
I complain quite often but on the other hand ... God I love Florida.
Old Jul 22, 2017 | 09:34 PM
Old Jul 24, 2017 | 05:08 PM
maxinout93's Avatar
Never seen it up close is it bolts on both sides that just unscrew?
Old Jul 24, 2017 | 05:31 PM
If you can get some welding done but you can just temporarily bolt it in until you can get a welding device.
You just line the new part up then drill a few holes through the new part and the subframe until your all the way through.
Then take the bolts(zinc) with washers/nuts and tighten them down.
This will stabilize the new part long enough until you can get some other more important repairs done.
